Old 06-12-2007, 09:14 PM   #3661
Hey Aaron
I was wondering if you could tell what size of crank case bearings I need for the Platinum Draked .21 engine? Mine are currently fine but I was thinking about getting some TKO ceramics to be safe. Also where is a good place to buy these bearings from?
Thanks for your time,
Ryan Birkett
birkett4 is offline   Reply With Quote
Old 06-13-2007, 05:46 AM   #3662
Whats up Aaron?
Homer Allman is offline   Reply With Quote
Old 06-13-2007, 11:26 PM   #3663
Thanks man! I have follow your recommendation and I have not had any problems yet. 1 gallon on the RTR already. The radio trey still flexes when going both ways, but I don't think it is going to be a issue for the servo.
- And with the servo horn remove, the RTR servo doesn't buzz
kmaheartless is offline   Reply With Quote
Old 06-13-2007, 11:33 PM   #3664
Aaron Waldron's Avatar
birkett - Sorry it took so long. I think they're 7x19x6 and 14x25.5x6.
Homer - Not much. Getting a little older, but still having fun.
kma - It's just important to make sure the servo isn't trying to rotate further than its mechanical limitations (pulling the carb too far, pushing the brakes too hard) and stalling. Try checking how hot your servo is after a few minutes of running your car. If it's really hot, you're probably over-stressing your servo.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-14-2007, 11:52 AM   #3665
Also I was wondering if you could tell me where to get a rebuild kit for the Draked .21 as Horizon doesnt seem to offer them. Or if they do and just dont have them listed.
Old 06-14-2007, 12:19 PM   #3666
smyka's Avatar
Send a message via AIM to smyka
Default set up
did you post your starting set up on here if not could you so i can compare it to mine
thanks
mark
smyka is offline   Reply With Quote
Old 06-14-2007, 02:46 PM   #3667
birkett - I'm not sure which distributors and hobby stores might have them. You can order replacement parts through Trinity here:
http://www.teamtrinity.com/shop/engi...lat122128.html
Mark - For the 8IGHT buggy? I run the stock setup with the following changes:
- 54's with 40 in the front
- 56's with 27.5 in the rear
- 4-A rear camber link
- 3/3 rear block
- Hubs all the way back (not sure if that's stock or not)
- 27mm front ride height 29mm rear ride height
- 95mm front shock length, 105-106mm rear shock length
- 13T bell
- Gold springs on blue aluminum shoes, black springs on carbon shoes
www.liverc.com
Old 06-14-2007, 02:50 PM   #3668
Davidka's Avatar
Trader Rating: 75 (100%+)
Aaron, have you tried 55/32.5 in the front? If yes, how did you like it? I am running that and I find the car can be pushed in the rough a little better. I changed from 54's in front and 55's in rear at the same time though.
Old 06-14-2007, 02:56 PM   #3669
I haven't changed anything in my front shocks. I had been running 55's with 32.5 in the rear for a while. I tried 56's/27.5 on a rough track that caused the car to kick, and really liked it.
My first adjustment to the front end would probably be a little more negative camber on a rough track, or moving to the top camber link hole in the shock tower to make the car easier to drive.
www.liverc.com
Old 06-15-2007, 03:20 AM   #3670
I measured the temperature of my server after running yesterday. It was around 100 F - 120 F on my 8ight rtr. Is this way to hot?
Old 06-15-2007, 03:42 PM   #3671
No way. 100-120 degrees is barely warm to the touch! Haha.
I'd imagine that if your servo is only that warm after running your car, you'll be in the clear. I've temped my servos around 160 or higher and they've been fine. If the servo is stalling, it will get much hotter than that.
www.liverc.com
Old 06-16-2007, 03:07 AM   #3672
Hi Aaron,what sort of setup would you run for my local track?
Heres a little vid,its very loose and dusty as you will see.
http://www.youtube.com/watch?v=D9LL7Sd8MMg
LOSI 8IGHT 2.0 ALIGN SERVO'S, RB C5bb,RB C6 L2G,PICCO P7R EVO2,
ASSOCIATED RC8T, NOVAROSSI .28 8PORT, SAVOX SERVOS.
CRT.5 SH .12,
damo666 is offline   Reply With Quote
Old 06-16-2007, 05:51 AM   #3673
Davidka's Avatar
Get those guys to water that track for cryin' out loud!
Old 06-16-2007, 07:44 AM   #3674
Turbine_au's Avatar
Got dust?
It's mine: http://au.youtube.com/watch?v=usYhSWbmx6s
Turbine_au is offline   Reply With Quote
Old 06-16-2007, 08:38 AM   #3675
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That looks like it'd be a really nice track if they'd lay some water down.
Jon Kerr is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
