Old 04-01-2007, 10:39 AM   #3346
Aaron Waldron's Avatar
Not a problem, have fun!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 04-01-2007, 10:43 AM   #3347
streetracer745's Avatar
Send a message via AIM to streetracer745
getting onto the subjects of engines, my 3.3 is acting up. it runs great. tons of power and speed in my revo. but it doesnt want to idle. i have the idle screw set as high as possible and still have to turn the trim up on my radio and i cant hit the brakes or the engine dies..... could this be a problem with tuning? what can i do to fix this? thanks in advance
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 04-01-2007, 11:01 AM   #3348
If it dies when you hit the brakes, chances are:
A) the carburetor is closing when you hit the brakes. Shut the engine off, take off the air filter, and hit the brakes. If your carb closes completely, that's your problem. The carb slide could be loose (rotating inside the carb), the idle screw is buggered up, etc.
or
B) the clutch is hanging up on the bell and killing the engine when the wheels stop. If you hold the truck up off the ground, rev it up to clean it out, let off the throttle (so it's basically idling), then push the truck onto the ground and stop all four tires, and it dies...it's a clutch problem.
Could be a broken spring, deformed shoe, etc.
www.liverc.com
Old 04-01-2007, 11:29 AM   #3349
well the clutch spring is real loose and i need a new one so... might be it. the clutch bell is cleaned out though. and the carb does close when i hit the brakes because i have to set it out real far to get it to idle. the slide valve is tight and isnt rotating. what do you mean the idle screw is buggering up?
Old 04-01-2007, 04:14 PM   #3350
Horatio's Avatar
Aaron:
How many 8ight T's have been produced to date?
I heard some interesting 'tales' that need to be put to bed!
Horatio is offline   Reply With Quote
Old 04-01-2007, 04:58 PM   #3351
Thanks Aaron I appreciate the help!
birkett4 is offline   Reply With Quote
Old 04-01-2007, 09:13 PM   #3352
Post
*still waiting bump*
Mabuchi540 is offline   Reply With Quote
Old 04-01-2007, 10:02 PM   #3353
streetracer - I've seen sport engines where the idle screw may not hold the carb barrel in place. Just an idea. If you hit the brakes and the carb closes completely, that is what is causing the engine to die. When you hit the brakes, the carb should still have a small opening, allowing the engine to get air (and stay running).
If the clutch spring is really loose, it may well be a clutch problem.
mabuchi - I'll make another call tomorrow. Last time I talked to them, they were working on getting you taken care of.
horatio - I don't have even the slightest idea, haha.
birkett - Not a problem.
www.liverc.com
Old 04-01-2007, 10:06 PM   #3354
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
i have a question.... i have alosi gtx and i was wondering if it is possible to run newer losi truck tires on the front and what is needed thanks.
cheesecake is offline   Reply With Quote
Old 04-01-2007, 10:40 PM   #3355
I'm not sure what all would be necessary (as I don't have one sitting here to look at) but you might need just the front axles in order to run the new wheels on your truck. At the most, doing a little bit of hand-modifying to use the XXX-NT (or AD2) front end pieces (from the caster block out) to use the new axles and wheels.
Check for clearance (so the wheels don't hit anything) and you should be able to make something work.
www.liverc.com
Old 04-01-2007, 11:00 PM   #3356
thanks ill buy the newer axles and see if they will work. thanks if not ill pickup the xxxnt parts and see if it will work
Old 04-02-2007, 02:08 AM   #3357
thanks i found somw info after searching all day i need to switch to xxt axles part number a1136
Old 04-02-2007, 10:33 AM   #3358
That will allow you to use the XXX-T and MF2 front wheels as well.
www.liverc.com
Old 04-02-2007, 04:21 PM   #3359
Send a message via AIM to WHITESTER
Aaron,
What's the theory behind your breakin method? Also, how to you get it up to operating temp with the stock settings? Are you talking about 200+ degrees?
I've always been told that if you do not get the engine up to atleast 200 you are doing more harm than good.
Thanks.
WHITESTER is offline   Reply With Quote
Old 04-02-2007, 05:35 PM   #3360
M2_Driver's Avatar
Default servo suggestions
Aaron-Thanks for all your help...
Any suggestions for servos?
Which starter box will work with the Drake?
M2_Driver is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
