Old 03-28-2007, 07:48 PM   #3331
M2_Driver's Avatar
I tired to get the OS 12 CV-R but was told it has been discontinued... .any other advice?
M2_Driver is offline   Reply With Quote
Old 03-28-2007, 07:55 PM   #3332
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
^^^The OS .12 TG
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 03-28-2007, 08:03 PM   #3333
Casper's Avatar
Trader Rating: 33 (100%+)
That sucks I wonder why? The TG is a rear exhaust. OS does not make a side exhaust engine anymore?????
I am not sure what to tell you for a good beginner engine anymore! Nova Rossi CX12 is a great engine but a little higher price.
Tower has CVR's but they are chargin 169! They used to be 109!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is online now   Reply With Quote
Old 03-28-2007, 09:00 PM   #3334
LOWGEARED's Avatar
So towers taken advantage of inflation!!!
Last in stock?
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 03-28-2007, 09:08 PM   #3335
XXX-NT series can use a rear exhaust, so the TG will work fine.
Old 03-28-2007, 09:26 PM   #3336
Casper's Avatar
Yes if you get the rear exhaust header. Side exhaust motors tend to be easier to drive though as they have a smoother bottom end. Good be beginners. Heck even drake uses side exhaust!
Old 03-29-2007, 11:12 AM   #3337
Aaron Waldron's Avatar
Casper - Haha, thanks. I've been running MC59's in both .12's and .21's.
stump - Thanks! That's always a big compliment from people that I try to help.
Factory Seal - Thanks! The problem with big races like that, is you'll have 50 people who rightfully expect to be in the top 15. Then you always have racers who felt like they came up short!
M2 Driver - Look into the Trinity Adam Drake Signature Series engine, not the Platinum one. They're really mild and easy to drive, get better fuel mileage than the O.S. motors did, and can be tuned to make good power when you are ready for it.
Side exhaust motors tend to have less bottom end, and more top. A-9347 is the part number for the Losi hard-anodized rear exhaust header, which comes in the AD2 kit.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-29-2007, 11:57 AM   #3338
Trader Rating: 25 (100%+)
do you run the .21 drake in the 8b?
if so , how do you like it?
buckeye-mac is offline   Reply With Quote
Old 03-29-2007, 12:45 PM   #3339
Yes, I run that engine in my 8IGHT and 8IGHT-T. It's awesome...really smooth and easy to drive, but lots of pull off the bottom and through the midrange. Not necessarily tire-spinning snap, but it pulls hard up hills, when loaded into the face of a jump, etc. I LOVE it, perfect fit for the free-spinning drivetrain of the 8IGHT buggies and trucks
www.liverc.com
Old 03-30-2007, 07:19 PM   #3340
Talking
I just bought a Platinum "Draked" .21 for my new 8ight
My question is whether or not I will need to add another head shim if I am running 30% trinity fuel?
Also could you walk me through the WOT break in procedure for this engine or reccomend what I should do to break it in.
Thank you for your time.
birkett4 is offline   Reply With Quote
Old 03-30-2007, 07:37 PM   #3341
Forgot to ask in my last post but what glow plugs are reccomended for this engine. Currently I am using rb6 or MC59 plugs in my Sirio Kanai Evo 2 and was wondering if these plugs will work ok for the Platinum engine.
Thanks again.
Old 03-31-2007, 02:03 PM   #3342
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Default Motor's
Here you go...........
No, they're not broken in. You're gonna think I'm crazy...haha:
Start the engine and let it come up to temp at the stock settings. Then richen the top 2 FULL turns and hold it full throttle for one tank. The engine will be blubbering, spewing fuel out of the pipe. Run 3-5 tanks through it like that (the engine will not be very warm at all by doing this, so no need to let it cool in between tanks).
Then tune it on the rich side and run it on the track for 3-4 tanks. Then you're good to go!
Aaron Waldron
RCTech Moderator
My club.....msra-racing.com
Factory Seal is offline   Reply With Quote
Old 03-31-2007, 03:51 PM   #3343
LOWGEARED's Avatar
Default Aaron (piston and sleeve)
I took the head off my mach15RE
to clean it off and noticed my sleeve pulls out really easy! is this normal or are issues with my engine?
premature ware maybe?
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Old 04-01-2007, 10:34 AM   #3344
LOWGEARED - The sleeve fitting loosely in the sleeve is not a result from wear, but manufacturing tolerances. If your engine runs well, I wouldn't worry about it.
birkett - Factory Seal posted the correct break-in. I run MC59's in my motors, the plug seems to work really well. I'm running the stock head clearance (not adding any shims) and 30% fuel.
www.liverc.com
Old 04-01-2007, 10:37 AM   #3345
LOWGEARED's Avatar
Thanks man I have posted that question everywhere and your the first to really come through!!! Ya it still runs great!!! Appreciate it!
LOSI YELLOW SPRINGS
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
