Old 03-13-2007, 03:12 PM   #3256
losi09's Avatar
Send a message via Yahoo to losi09
Originally Posted by rezenclowd3
To break in new diffs, tighten the diff (dont crank down though) and grab a tire and give it gas. Do that for a minute or so, then check the diff screw again, make sure to tighten it back up, but dont crank down on it. Then grab the other tire and do the same. I do this for 5-10 minutes.
Cool thanks for the info, I will give that a try the next time I rebuild my diff. When u brack in a diff do they last a lot longer? then when u do not brack them in?
losi09 is offline   Reply With Quote
Old 03-13-2007, 09:31 PM   #3257
Aaron Waldron's Avatar
The diff is going to break in no matter what you do, haha. If you do it in the pits, it won't have a chance to slip when you're running it on the track. If you build the diff brand new, throw it out on the track and run it, it will loosen up as the parts break in and seat together, and you take a chance of making the diff slip.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 03-13-2007, 09:37 PM   #3258
okFAB's Avatar
Aaron, are you going to be racing at Revolution Raceway this weekend?
Also, I have a xxx-nt, what setup would you recommend (for the revolution track). The truck is currenty set up identical to drake "dirt setup". Any other changes needed or run it as it is?
Thanks!
-Kyle M.
okFAB is offline   Reply With Quote
Old 03-13-2007, 09:39 PM   #3259
losi09's Avatar
Oh I see...
Old 03-13-2007, 11:04 PM   #3260
okFAB - The only adjustment I'd try at Revelation would be going to long-arm in the rear, which can help add sidebite and tame-down some of the wheelies. Otherwise, the Drake setup is right at home on a track like that.
I'm not sure where we're racing this weekend. I leave Tuesday for Vegas, so it's going to depend on how much I want to run my cars this week.
www.liverc.com
Old 03-14-2007, 11:02 PM   #3261
arghh's Avatar
aaron..
runaway is really scaring.. when it happen, how to recognise that it is because of:-
- servo
- reciever
- transmitter
- cristal
- low battery power
- glitching/same frequency
arghh is offline   Reply With Quote
Old 03-14-2007, 11:21 PM   #3262
There's really no special trick to diagnose radio problems. Sometimes the problems may only arise when the engine is running (usually a vibration issue, with metal-on-metal contact).
I had radio problems a few weeks ago, where the car would turn full lock to the left as soon as I hit full throttle. We switched out components one at a time until we narrowed it down to be the steering servo. Took a while to narrow it down though.
The best thing you can do, is keep your stuff in good condition, keep your battery charged, and hope for the best!
www.liverc.com
Old 03-14-2007, 11:34 PM   #3263
cornerspeed's Avatar
Doesn't hurt to say a little prayer to the R/C God's everytime time you fire up that engine.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 03-15-2007, 12:12 AM   #3264
Post Or you could try the novel approach and.....
do it the way it says in the instruction book.....just a thought.
Mabuchi540 is offline   Reply With Quote
Old 03-15-2007, 02:33 AM   #3265
Don - Hahaha. No kidding.
Mabuchi - No need for the attitude. It's just a question.
www.liverc.com
Old 03-15-2007, 02:36 AM   #3266
Post ....and......
my reply was just a joke, I'm fairly sure that's what <<< one of those indicates.
Old 03-15-2007, 09:44 AM   #3267
Factory Seal's Avatar
Trader Rating: 29 (100%+)
Default racin
And run a return spring on that thing man.....If it does happen to get away from you atleast it wont be wide open!! LOL!! I still see vets not chargin there batts... lmao!! and oh ya thanks Spectrum!!...
Just my 2 cent's
My club.....msra-racing.com
Factory Seal is offline   Reply With Quote
Old 03-15-2007, 02:31 PM   #3268
A throttle return spring is extra insurance, but it's not going to save you from much. I can count on one hand the times I've seen throttle linkage pop off (if you put the return spring on the carb). If you are having frequency or component problems, a return spring won't do a darn thing. The only time a return spring will work, is when the car loses battery power, due to a bad solder joint or dead battery. Even then, many servos are hard to pull back, and a spring stiff enough to pull it back will add stress to the servo when it's working properly.
With that said, it's still a good idea.
www.liverc.com
Old 03-15-2007, 09:01 PM   #3269
Default Tires
Point well taken.........
Hey Aaron,Does anyone make tire's for the Eight-T wheel's?
And also is there any word of Losi releasing more pattern's any time soon?
I just ordered three back up set's........Man i sure do like havin options in the tire department!! LOL!
I believe Losi is on to sumpin with this tire and wheel package
No sidewall roll over might just be a good thing
Later bro.....
Old 03-15-2007, 11:11 PM   #3270
Bigedmond's Avatar
Trader Rating: 18 (100%+)
hay aaron, when you out here, you should stop by the sin city rc track. It is like nothing you have ever driven on. Offroad track, but with the tracion of a carpet. If you do want to check it, bring some old tires, because they will go bald, and you will still have to much traction.
Bigedmond is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
