Old 02-07-2007, 02:30 PM   #3076
Aaron Waldron's Avatar
Still digging. Thanks for the patience
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 02-07-2007, 02:56 PM   #3077
Default Lipo
Does anyone here use Lipo reciever packs? If so do you need to run a voltage regulator, or can most recievers handle the extra voltage?
Dale.0 is offline   Reply With Quote
Old 02-07-2007, 03:45 PM   #3078
I'm not positive, but I think you need to run some sort of regulator to protect your receiver and servos.
Like this one:
http://www.teamnovak.com/buy/ind_buypgs/5460.html
www.liverc.com
Old 02-07-2007, 06:22 PM   #3079
SEADOO's Avatar
Originally Posted by Aaron Waldron
losi09 - Unfortunately, I haven't been down to Family yet, not even to check it out. I suppose I'll make my way down there...someday...haha.
It's awesome to hear about a good facility in San Diego County again, and I know of a lot of racers I've known for a long time have been racing out there.
Tim - Awesome, that's it!
SEADOO - Did you make sure to line up the notch in the pin so that the set screw can hold it in? And use loctite? Loctite's really important for joints like that.
Hi Aaron,
The pin that came out from the dog bone is on the other side of it. It does not have any set screw.
SEADOO is offline   Reply With Quote
Old 02-07-2007, 06:24 PM   #3080
SEADOO's Avatar
Originally Posted by SupermaxxRich
If you clean everything well with brake clean, use good locktite and make sure the flat on the pin is ligned up you should never loose a pin. I don't run any shrink wrap on my pins and haven't lost one in 2.5 gallons
Hi, the pin that comes off is from the other side of the drive shaft. It does not have any set screw to hold it. I think the part is faulty from the factory.
Old 02-07-2007, 06:35 PM   #3081
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Are you going to run the Proline Saturday series and/or the JBRL series this year?
Jon Kerr is offline   Reply With Quote
Old 02-07-2007, 06:50 PM   #3082
cornerspeed's Avatar
Mine had the same problem, but mine was like that out of the box. They sent me a new one. Its all good now.
Ask Aaron Waldron-picture10-10-05-003.jpg   Ask Aaron Waldron-picture10-10-05-005.jpg
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 02-08-2007, 12:03 AM   #3083
SEADOO - Oh! Call Losi and ask for Bill or Jeremy, and explain what happened. They are the ones who will be able to help you.
Jon - Both! I've run the Saturday Series every year since its inception, and I'll definitely support anything JB puts on, especially if it's gas racing
www.liverc.com
Old 02-08-2007, 01:05 PM   #3084
LOWGEARED's Avatar
This may sound like the dumbest ? ever in the history of this forum? I have a camera phone to take my pictures and post with! How can I blow them up and post them on here? Is there a special tool on this site for it?
MEGA BAJA HOP UP LIST:
GPM BLUE ALUMINUM THREADED SHOCKS
LOSI YELLOW SPRINGS
GPM BLUE ALUMINUM A-ARM SET U/L
ACNCM ENORMOUS COOLING HEAD
INTEGY SWAY BAR KIT
VANTAGE HX5 TIRES
Micro baja
Micro raminator
ALUMINUM PIVOT BLOCKS
FULLY ADJUSTABLE C/C/S
LOWGEARED is offline   Reply With Quote
Old 02-08-2007, 02:18 PM   #3085
streetracer745's Avatar
Send a message via AIM to streetracer745
how do the number of winds affect a motor? ive heard that a double wind motor has more initial torque. ive also heard that a single wind has more initial torque though.... which is right? and what is a good motor for under $50. preferably a 10-12 turn
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 02-08-2007, 02:21 PM   #3086
AzBobby's Avatar
Aaron i don't know how i missed you friday at the pit. i saw drake and truhe,billy,casey and the others. but anyways glad you had fun. we'll do it right during the challenge.
GO TECH
AzBobby is offline   Reply With Quote
Old 02-08-2007, 02:32 PM   #3087
Casper's Avatar
Trader Rating: 33 (100%+)
A single will have more bottom. Mutistrands will take a little bottom away and stretch out the power band to make the motor a little smoother. They will also gain a touch on the top end.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 02-08-2007, 02:37 PM   #3088
is the team orion SV2 BB 10 turn single a good motor? will it last a long time and have torque in a tamiya dark impact?
Old 02-08-2007, 05:00 PM   #3089
Jon Kerr's Avatar
I'm not Aaron (Thank God! ) but in a 4wd buggy, I always preferred to run a single (9 or 10 single usually) for the extra punch. You can use that extra punch with a well setup 4wd buggy. That's why you see most guys running 2wd running a double or triple. They don't have the traction to handle that much torque. However, if you're just getting into modified racing, you may want to stick with a double and maybe a higher turn (11 or 12) until you get used to the extra power. A 9X1 in a 4wd buggy can be a rocket.
I don't know about the Orion Sv2. In all honesty, if you're looking for a good off road motor that the brushes are going to last and you're not going to have to cut every other run, I'd go with a Checkpoint or the Trinity Cobalt2. I haven't run the Trinity, but the CP motor is good.
Old 02-08-2007, 05:13 PM   #3090
i was thinking checkpoint, but didnt want to spend that much for a system. i raced mod 2wd for a season and just recently got my tamiya dark impact. so a good 10 turn single motor would be great for the buggy? what final drive should i use? what do you use in your buggy? if you have one that is. is there any good 10 turn for under $50 that i wont have to rebuild all the time? i hate motor maintenance but cant afford brushless.
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
