Old 04-12-2004, 02:12 AM   #16
Suspended
Gabe Boudreau's Avatar
Send a message via AIM to Gabe Boudreau
Gabe Boudreau is offline   Reply With Quote
Old 04-12-2004, 05:24 AM   #17
slodsm's Avatar
Trader Rating: 19 (100%+)
Aaron good to see you over here man, I was not sure if you knew there were any sites other than the grid . Congrats on your last year man, you are doing great. I am pretty sure I caught a glimpse of you in Xtreme RC or RC car in the last couple of months as well.
Tekno NT48.3/Novarossi Mito 7, Tekno NB48.4/Protek LS5, Tekno EB48.3, XRAY XB8/Reds R7.
slodsm is offline   Reply With Quote
Old 04-12-2004, 06:27 AM   #18
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Aaron,
Whats your XXX-T setup? I'm dialed, I just like to know what everyone else runs.
Thanks!
mafiaracers is offline   Reply With Quote
Old 04-12-2004, 12:09 PM   #19
Suspended
Old 04-12-2004, 12:26 PM   #20
Send a message via Yahoo to TambokGT
Aaron,
Are you the race director from the US GAS CHAMPS?
If so you did an awesome job.
TambokGT is offline   Reply With Quote
Old 04-12-2004, 10:32 PM   #21
Aaron Waldron's Avatar
Gabe - Man those were the days... it was really a bummer to see MnM disappear into the sunset.
slodsm - Actually, it was someone else from the Grid that asked me to help out over here!
Thanks for the props..last year was a long time in the making.
TambokGT - That was me..and thanks! That was a lot of fun.
Aaron's XXX-T setup:
Front:
35 wt. on 7's
Orange springs
Shocks 2 on tower, middle on arm
Ride height arms level
2-B link w/ two washers
.120 limiters with .9 shafts
-1/2 deg. camber, very slight toe-in
Rear:
30 wt. on 6's
Pink springs for stock, Red for Mod
Shocks 2 on tower, inside on arm
Ride height arms level (not bones)
2-A link, stock rear hubs, spaced middle
2 deg. anti-squat
Misc:
- Alum. dogbones and plastic outdrives for stock.
- Alum. topshaft
- Fury body
- Battery 1/2 inch back
- 357 servo
- Trinity front and rear pivot blocks, shock collars
- Stock P2K2 geared at 18/86, mod D5 11x2, gearing changes by track
- Trinity GP3300's
WARNING: this setup works best on blue-groove tracks like Hot Rod and SRS, and will get you in the ballpark for basically every other track (I never change it). It may not have enough steering for tight indoor tracks like SoCal..in which case, try Red Springs up front, and more drag brake than normal. At tracks like Hot Rod for stock truck, I set my drag brake to the point where the truck will roll unless I hold the brake on.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 04-13-2004, 12:26 PM   #22
I find that all you "pros" run the front end so soft....well, at least the spring. I am a fan of the 2" blue-green. Kind of wierd...
Old 04-13-2004, 02:34 PM   #23
It's a pretty even split actually. Kinwald, Truhe, and many of the Losi guys that race on tight indoor tracks use the 2" blue springs up front, because the setup that goes along with it gives the truck more steering.
I feel more comfortable running this setup for a couple different reasons, but a lot of it is that many big races don't have constant 180 after 180 like some tracks like SoCal have, and this setup is very easy to drive smoothly through flowing turns.
www.liverc.com
Old 04-13-2004, 02:57 PM   #24
Richy89's Avatar
what high school do you go to or did you go to??
Richy89 is offline   Reply With Quote
Old 04-13-2004, 03:47 PM   #25
Aaron,
If your truck or buggy just doesn't seem to have quite enough steering for your needs, do you look to a setup change, or a controller adjustment?
Thanks!
Old 04-13-2004, 04:02 PM   #26
Suspended
Old 04-13-2004, 04:29 PM   #27
Well, I guess since were on the subject of setups...I havn't come around to buying the BK2 yet, could you post your BK1 setup please?
Thanks!
Old 04-13-2004, 04:30 PM   #28
Richy - I'm a senior at San Pasqual.
mafia - I assume you're talking about the XXX-T, right?
The first thing I do is put on new front tires; I always start with Red compound tires on loamy tracks, and Silvers on hard-packed tracks. If the track is loamy, and I need more steering, I will go to Silver compound tires. That will usually fix it immediately.
If the track is hard-packed and most people are running Taper-Pin front tires, 8-ribs will give you more steering. Hard-packed tracks are backwards from loamy ones; softer tires will give you more steering.
After tire changes, I will remove one washer from the front inner ballstud. After that, I would move the ballstud to the outside hole with one washer. I try to stay away from shock changes, because it will affect how the car jumps and goes through bumps.
If that still hasn't helped enough, or I want a little more steering during or immediately before a race, I'd dial in more drag brake on my radio (just turn the throttle trim down slightly).
Other things to try:
- Add one gold washer under each side of the front of the pivot block to give you more anti-squat; this gives you 3 degrees of anti-squat, and will give you more forward bite, and more on-speed steering.
- Raising the rear ride-height and/or raising the rear will give you a little big more steering, but can change the attitude of the car as it jumps.
- Softer front springs (Reds) will give you more steering but will change the way the truck jumps (and particularly, lands off jumps).
www.liverc.com
Old 04-13-2004, 04:40 PM   #29
BK1 setup (works best in stock, I didn't start racing mod until the BK2 came out)
Front:
30 wt. on 6's
Green springs
1-B link w/ one washer
Rear:
30 wt. on 6's
Pink springs
Bones level
2 deg. anti-squat
Misc:
- Alum. topshaft
- Phobia body
- Battery forward
- 357 servo
- Monster geared at 19/82
- Trinity GP3300's
I'm not sure what exactly is in my BK2 right now..and I've never run it at Hot Rod. I will post the setup on the car tonight.
www.liverc.com
Old 04-14-2004, 06:52 AM   #30
Aaron,
I'm a total nut when it comes to gear ratios, and (stock) motor temperature and preformance so please bear with me. Seriouesly, I may TQ, but if the motor is on warmer than I want it to be...it ruins the moment. Hopefully you can put my mind at ease. When you're racing stock...as long as you're not getting soft before the race is over and the motor "feels" good, do you even give a rats A$$ about motor temperature? That's what people are trying to tell me...hopefully you can tell me the same thing.
Also, as for gearing and ratios. You said you run an 18-86...thats an 11.61 gear ratio. The track I race on is pretty small and tight and the only straight in this layout has a single at the beginning and one in the middle....so you can't really judge where its maxing out. However, I like a motor with a little more initial "uumph." So I crunched some numbers and came up with 17-82 which is an 11.721 gear ratio. The difference from yours and mine is .111. Is it ok to step out of the box, or should I run the norm?
Thanks for bearing with me!
Chris
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
