Old 06-12-2006, 11:24 AM   #2776
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
I've heard from two people that its today...
killer89 is offline   Reply With Quote
Old 06-12-2006, 11:34 AM   #2777
Casper's Avatar
Trader Rating: 33 (100%+)
I would expect the Horizon site to update that they are in stock then. I will be checking my LHS later today to see if they got them in!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 06-12-2006, 02:24 PM   #2778
Aaron Waldron's Avatar
Tough Kevlar gears are good! Who cares if they're noisy.
binary - I'm a confused 20 year old who gets into trouble all the time...you're asking the wrong person, LOL.
Casper - I haven't heard anything. It's an electric car...
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 06-12-2006, 04:32 PM   #2779
Casper's Avatar
I figured you would know something since the HRH shootout is coming up. You usually play with us flashlight guys for that race while you wait for rut rut. You going to that race this year?
Old 06-12-2006, 04:41 PM   #2780
Dang...the answer is 42...
binaryterror is offline   Reply With Quote
Old 06-12-2006, 06:25 PM   #2781
The meaning of life is 42? That's more confusing than searching for the answer...
Casper - I'll be at the Shootout, for sure!
www.liverc.com
Old 06-13-2006, 02:57 PM   #2782
Aaron, Can you try to find out when the xxx-cr will ship out for us. thanks
rgb24 is offline   Reply With Quote
Old 06-13-2006, 04:04 PM   #2783
killer89's Avatar
Losi generally ships them so that they arrive on both coasts on the same day. From what I've heard, shipping started this Monday, so people have been speculating Thursday on the shelves.
Old 06-13-2006, 08:22 PM   #2784
Is there a simple method of removing glued tires from a set of rims, or is it standard practice for those who race often to keep buying new rims along with their tires?
iluminati is offline   Reply With Quote
Old 06-13-2006, 08:27 PM   #2785
I tried baking them in the BBQ in the back yard and that worked really well. Heat to about 400 and then set them in with the oven/BBQ off and let 'em sit for a while. Breaks the glue down nicely. Careful on the oven though...they stink when baked...lol.
Vegaspilot is offline   Reply With Quote
Old 06-13-2006, 08:44 PM   #2786
killer89's Avatar
Acetone works AWESOME for me. Depending on the glue used, some tires just fall right off after being soaked for 1 hour and some need 24 hrs and a little tugging...
Old 06-13-2006, 09:23 PM   #2787
Trader Rating: 112 (100%+)
Send a message via AIM to Valentin.H
for the tire removal...cut the tires off till only the glued parts of rubber from the tire are sticking to the rim (so cut off everything except for the sidewalls..) and soak them in acetone..most people just soak them in acetone, and the rubber should come right off with a slight pull..like killer said...also depends on what glue was used...if u used really strong glue..it will be alot harder to take off unlike the glue i use..and i get it from the 99 cent store. ROFL! the glue works great though for only a buck!
-valentin
www.csjunkies.com
Valentin.H is offline   Reply With Quote
Old 06-14-2006, 01:34 AM   #2788
rgb - Looks like killer89 got that taken care of.
I've heard of the oven trick...personally, I've only ever used acetone to re-use old rims. However, it is (or should be) standard practice to replace rims that are tweaked, bent, or otherwise beat up.
www.liverc.com
Old 06-14-2006, 05:50 AM   #2789
TripleX-JT's Avatar
Send a message via MSN to TripleX-JT
What works best for me is boiling them in water.
Josh Thompson
CEN Racing - GO Tech Engines - UPgrade RC - Northern Hobbies - Khaos Designs
TripleX-JT is offline   Reply With Quote
Old 06-14-2006, 12:03 PM   #2790
Anyone know if a BK2 front shock tower will fit on an XXX-T MF2? I was thinking of installing a BK2 body but it appears I need the BK2 shock tower and some rear posts.
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
