Old 01-16-2006, 09:02 PM   #2716
Im pretty sure they are running either C-compound panther switches, or the New M3 inside jobs.
runnin rc10 is offline   Reply With Quote
Old 01-17-2006, 05:20 AM   #2717
Davidka's Avatar
Trader Rating: 75 (100%+)
runnin rc10 is right. Get the Panther Switches in C compound. That is the best tire for that track without a doubt.
Old 01-17-2006, 07:45 AM   #2718
Trader Rating: 14 (100%+)
If it was legal to run pink taper pins, I would do that, but other wise your best bet is the clay switches, but make sure you get the clay compound or you will be significantly slower than everone else. I would stay away from the inside jobs, I have a pair and I was greatly disapointed with them.
And get some trinity buggy grip too, it won't make a difference immediately, but after 3-4 applications you will notice your tire is softer than before and the grip level goes up significantly.
If you are running 1/10 truck, run pink tapers all the way around, I do that at my local track and it works better than having ribs up front. Makes the steering much more consistent.
o.s. power is offline   Reply With Quote
Old 01-17-2006, 09:46 AM   #2719
At the Midwests this past weekend we were running pink Tapers cut down to almost slicks in the morning and early afternoon then switching over to half to 3/4 tapers as the track dried.When the humidity went up track held
moisture and we went back to 1/2 cut Tapers.Frts were dremmeled down directionals with most of the tread cut on the inner 1/2 of the tire and the outer half we left 3/4 tread. Some were also running tapers on the frt that also looked to be cut down,but how much I dont know.
gearhead is offline   Reply With Quote
Old 01-17-2006, 05:00 PM   #2720
Capelracer's Avatar
Aaron,
Dusted off my XX-CR to get back into off-road racing, but am out of hydra-drive oil. Is the slipper assembly off the XXX a direct swap, or can I modify the XX slipper to take two slipper pads?? Also, are the wider XXX front wheels a direct bolt on to the XX?? (I'm 200 miles away from the nearest losi parts supplier & got a big 'dunno' from them when I asked them)
Capelracer is offline   Reply With Quote
Old 01-17-2006, 05:07 PM   #2721
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
Capelracer: WTF is that avatar pic? Is that a lady doing what I think she's doing?!?
killer89 is offline   Reply With Quote
Old 01-17-2006, 05:58 PM   #2722
that avatar is pretty goddamn offensive and gross.
Old 01-18-2006, 06:52 AM   #2723
thedoc329's Avatar
thanks guys, leaving in about 18 hours, cant wait!!
thedoc329 is offline   Reply With Quote
Old 01-18-2006, 10:47 AM   #2724
Trader Rating: 26 (100%+)
Default MF2 Body
Can you tell me if the Body that comes with the kits have the plastic film on the outside that you peel off after you paint?
svines1972 is offline   Reply With Quote
Old 01-18-2006, 06:26 PM   #2725
killer89's Avatar
check with ur fingernail... scrape the outside in an unused ared...
Old 01-20-2006, 12:02 AM   #2726
Aaron Waldron's Avatar
capelracer - Thank you for changing your avatar...I didn't catch it, but I appreciate you changing it instead of letting it become an issue. XXX front wheels will fit the XX. The XXX dual disk slipper should be a direct replacement for the slipper and hydra-drive on the XX buggy.
http://www.teamlosi.com/ProdInfo/Fil...plodedView.pdf there is the exploded view of the BK2, which will have the slipper assembly.
svines - Losi bodies do not come with that film.
thedoc - Sounds like they got you taken care of :-) Good luck!
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 01-20-2006, 09:49 AM   #2727
AW
why do you and adam like running a slower throttle servo for truck???
thanks
dave mac
ps
bubba is gonna kick but this weekend LOL
D Mac is offline   Reply With Quote
Old 01-20-2006, 09:37 PM   #2728
Bubba will have a good shot at winning....if he keeps his head off of the Anaheim stadium floor!
A 94737 is really all you need for a gas truck throttle servo. They have enough torque to clamp the brakes on, and you can't really wick the throttle open any faster, so there's no reason to run any more servo and drain the receiver pack any faster.
www.liverc.com
Old 01-21-2006, 04:39 AM   #2729
AW
Thanks for the quick responce.
Old 01-22-2006, 10:42 AM   #2730
Aaron- Last I read you where running the Sirio green head Kania engine on your CR Pro? You said it had tons of power and was very smooth with the throttle reponce? My question is how it tuning wise? I have nitro experience, but race tuning a bigblock is new to me, just as 1/8th scale racing.... would you recommend a Nova based P5 (factory standard engine not modified) or the Sirio????
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
