Old 12-08-2005, 01:06 PM   #2671
Aaron Waldron's Avatar
Casper - It all depends..I usually run XTR's, and I know they're better when the track is soft, or very abrasive, or it's hot outside. M2 can be better when it's cold though.
tcmerf - I've only run at ARC once and I think I used IFMAR Pins..whatever I used that date, I remember laughing about how dialed they were. T-Bones usually work best when the track is dry and pretty hard-packed. Taper Pins require a pretty much dust-free and packed surface to work...they're the best at Hot Rod when it's dry, but I don't think you'll be using them much at ARC.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 12-08-2005, 01:22 PM   #2672
Casper's Avatar
Trader Rating: 33 (100%+)
HOW LONG TO IFMAR PINS LAST!
Sorry I should not yell but do you run a new set every qual or to they last longer out there. I have only run stk and 19T electric out there with ifmar pins so I do not know how long those tires I lasting. I need to start buy tires for the nitro challenge to make sure I have enough. They can be hard to find at times!
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-08-2005, 01:44 PM   #2673
You can get 2-3 runs out of them pretty easily before they start to drop off in performance.
www.liverc.com
Old 12-08-2005, 01:57 PM   #2674
Casper's Avatar
Sounds good. I should not need more then 3 pair. Are you guys changing tires in 30 min mains? Last one. You running stock losi foam in them?
Old 12-08-2005, 02:15 PM   #2675
Stock foam, 45'd outer corners, glued to the rim.
No change in a half hour, but probably around the 25 minute mark for a 45 minute main.
www.liverc.com
Old 12-08-2005, 02:26 PM   #2676
Casper's Avatar
Thats what I needed to know. Thanks!
Old 12-08-2005, 02:30 PM   #2677
Thanks Aaron. The last time i was there the track was holding a lot of moisture, the tires looked pretty caked coming off. Of course this was at night and it was pretty cold out.
FT B44 - FT J82
LRP TC SPHERE - Futaba Fasst
Orion Lipo & Vortex motors
" Go that way really fast, if something gets in your way, turn"
tcmerf is offline   Reply With Quote
Old 12-08-2005, 03:22 PM   #2678
Usually when a tire cakes, it's a good sign that it's doing its job. That's never a bad thing.
Sometimes, tires cake up and you lose traction, usually when the dirt is really muddy or slimy. Even other times still, the only way to get traction is to let your tires cake up and have "dirt on dirt" traction.
www.liverc.com
Old 12-08-2005, 03:32 PM   #2679
Sofast-NT's Avatar
Aaron,Thats good to hear you are coming to the nats.Hopefully i'll see you there.
Sofast-NT is offline   Reply With Quote
Old 12-08-2005, 03:36 PM   #2680
Casper's Avatar
Dirt to dirt traction is sometimes the best kind. In these cases though something with a smaller pin like an ifmar pin is better then say a step pin as the step pin will just collect even more dirt making the tire very heavy. You know you went too small when the tires stops collecting mud and it will become skaty then.
Old 12-08-2005, 03:37 PM   #2681
I can't wait :-)
www.liverc.com
Old 12-08-2005, 03:48 PM   #2682
Thanks guys. I have been out of racing for a long time so i need all the help i can get. the last big race i went to Pro line Fuzzies were the ticket at SRS. My only A main ever! so what if there were only 18 guys, i was on the same drivers stand with Pavidas and Kinwald!
FT B44 - FT J82
Old 12-08-2005, 05:57 PM   #2683
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
killer89 is offline   Reply With Quote
Old 12-08-2005, 08:43 PM   #2684
Default AD2 Setup
I was wondering what "minor" adjustments do you do after setting up your truck w/ "the dirt" setup? I mainly race on a med. sized indoor hard packed track. The tires of choice are red tapers rear, tapers or 8-ribs front. I'm running silver 8-ribs up front because they seem to be more consistent throughout the day especially after the monster trucks. Anyways "the dirt" setup is dialed especially going around the 180's. What adjustments would increase my high speed steering (rear slides out) w/o sacrificing too much low speed steering. I've already tried going to long rear arm and moving the camber to 2-b (adj. made independently), and the truck does not rotate as well in the sharp corners. Those were too major of adjustments. Any help would be appreciated. Thanx..
Ultra7M is offline   Reply With Quote
Old 12-08-2005, 10:01 PM   #2685
Hey I think you posted your picture in the wrong thread, this is an off road thread. You need the cross dressing thread
Charles is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
