Old 09-21-2005, 06:30 AM   #2536
Trader Rating: 38 (100%+)
Aaron is the bomb diggity!
Breakin2 is offline   Reply With Quote
Old 09-21-2005, 03:34 PM   #2537
Aaron Waldron's Avatar
Shoulda seen this place when I was gone for a couple months...shambles! lol
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 09-21-2005, 04:42 PM   #2538
SpeedBump57's Avatar
Homer the new site looks real good. I just sent off my reg-info. I also sent you an e-mail on something I found on your site.
Scott
SpeedBump57 is offline   Reply With Quote
Old 09-22-2005, 05:33 AM   #2539
Thanks Scott
Aaron do you what weight Xray 400 is compared to Losi. So in other words Xray 400 equals what in Losi.
Homer Allman is offline   Reply With Quote
Old 09-22-2005, 07:24 AM   #2540
Aaron,
My friend has a XXX-NT RTR. Lately his diff gear has been melting. Ya, melting. Those little steel balls in the diff must be getting way way hot, and melting the gear. What could be causing this?
VelvettFogg is offline   Reply With Quote
Old 09-22-2005, 07:37 AM   #2541
Trader Rating: 27 (100%+)
Running it too loose and not checking it. Also using the wrong kind of grease on the diff can do it also.
jbrow1 is online now   Reply With Quote
Old 09-22-2005, 03:25 PM   #2542
Also, use the Team Associated "stealth diff lube" in the diff. Some of Losi guys use this and is somehow made with a tiny, microscopic grit that helps the diff.
the dirt is offline   Reply With Quote
Old 09-22-2005, 11:54 PM   #2543
The stock Losi diff lube is good. AE black thrust bearing grease works really well.
Homer - No idea. I know there's an SAE vs. metric conversion on the Grid somewhere.
velvetfrog - Scroll back a bunch of posts on this thread...there's a post dedicated to making a Losi diff last. The post was on 9-15
www.liverc.com
Old 09-23-2005, 08:08 AM   #2544
Casper's Avatar
Trader Rating: 33 (100%+)
Originally Posted by Homer Allman
Thanks Scott
Homer-- Check out this thread on xray's web board
http://www.teamxray.com/xforum/viewt...ight=shock+oil
and this site has some pretty good conversion info as well
http://www.twf8.ws/new/tech/tip/shock.html
Hope this helps.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 09-24-2005, 12:23 PM   #2545
Casper hitting cleanup!
www.liverc.com
Old 09-27-2005, 09:10 AM   #2546
Since this is the Ask A-Duh thread...
What was the best thing before sliced bread ?
dkingston is offline   Reply With Quote
Old 09-27-2005, 09:28 AM   #2547
Casper's Avatar
swiss cheese. It is a sandwich theme! LOL
Old 09-28-2005, 10:04 AM   #2548
J.Filipow's Avatar
Trader Rating: 15 (100%+)
What's up RUT RUT!!??? See you back at Hot Rod soon?
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 09-28-2005, 10:52 AM   #2549
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
Aaron, I just got me an AD1 for cheap, but I have 3 new motors, and dont know which to put in it.. I have a new Fantom FR12, a broken in only OS Max 12CV, and another just like it...
what should i use>?
losirunner is offline   Reply With Quote
Old 09-28-2005, 10:53 AM   #2550
Registered User
losirunner's Avatar
and this is the Diff thing aaron was tlking about guys...
High bite carpet is a textbook example of when you need to run a diff. A 2wd car will push off the track without one!
When the diff is gritty, it's often the thrust bearing. Clean everything with motor spray right out of the package and try using Associated black grease on the thrust assembly. Put it together according to the instructions and work the diff back and forth with your hands as you tighten it...tighten a little bit, work it back and forth, and repeat.
To test the diff, put an allen wrench through each outdrive to hold them still and try to turn the diff gear. If you can turn it, you need to tighten the diff more.
Once it's in the car, hold the car up by the rear end of it and apply 1/4 throttle to get the wheels turning. Use the pit table or ground to stop one tire for five seconds, then the other, back and forth, about five times each. This will break in all the parts and allow everything to seat. When everything breaks in, the diff usually loosens up, and that's why people melt new diffs.
Lock your slipper down, hold the right rear tire and spur gear with your right hand, and try to turn the left rear tire. If you can turn it, then you need to tighten the diff. Do this until you can't turn the left rear tire. Back your slipper off the recommended adjustment in the manual, and do the test again. You should find that you'll be able to turn the left rear tire with some effort, and that the slipper shaft, nut, and spring all turn. If you can't turn the left rear tire, back the slipper off until you can.
Keep checking your diff and slipper adjustment every run or so and it will last for a long time!
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
