Old 04-13-2005, 02:52 PM   #2341
Casper
I am tied of breaking tierods and a few pages back you suggested the Lunford SD tie rods wit hRTR ball cups. What are you using on the inside rear camber link?
toddzhere2 is offline   Reply With Quote
Old 04-13-2005, 02:58 PM   #2342
Casper's Avatar
Trader Rating: 33 (100%+)
I am only running those on the gas truck. I run all superduty tie rods with RTR ball cups. I run Titanium balls studs in all 4 places in the rear and titanium in the inner camber in the front.
For electric I am still running punisher tie rods but you need to run the lunsford ones. The kit tie rods are junk! Do not know why losi tried to mess with a good thing in the tie rods but they did and lost.
Did you get to try the batteries yet?
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 3.0, TLR 22SCT 2.0, TLR 22-4 2.0, TLR Ten-SCTE 3.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 04-15-2005, 03:18 PM   #2343
scrubnick's Avatar
Send a message via AIM to scrubnick
Why does Jeremy Felles suck so bad in gas?
scrubnick is offline   Reply With Quote
Old 04-17-2005, 01:46 PM   #2344
Aaron Waldron's Avatar
Casper is dialed.
Nick - Haha! Maybe it's his mechanic?
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 04-18-2005, 06:51 AM   #2345
dkj-M3's Avatar
Captured ends - so far the dubro Monster ball ends are great, no slop after some hard running for test & tune day on a super cross type track & letting someone else drive my truck, whoa.
dkj-M3 is offline   Reply With Quote
Old 04-19-2005, 03:56 PM   #2346
dkj-M3's Avatar
Aaron, whuts up dog. You ever try silver directionals at Hemet & Sun-valley? If so, how did they compare to red directionals?
I finally got a chance to play with different set-ups on the AD2 for my 1st test & tune out-doors. All I have to say is that it's ON, this summer. My truck is way more dialed than my old AD1 ever was. Seems I'm running the hole in the rear hub that has the least sidebite, so if I'm ever on a very slick track, I have 3 more steps to gain additional side-bite.
thx...KJ
Old 04-20-2005, 06:06 AM   #2347
Default setup
I just finished putting "the dirt" set up in my car and I'm ready to give it a try for tomorrow night. Per the set up sheet, I have #56 pistons all around but I noticed for the front they are standard and in the rear it says "drilled". Is there a standard to use when someone says "drilled pistons"? Like, do you open up one or all of the holes with a certain size drill? To you add a hole of a particular size? Any info is appreciated.
Also, I added the .020" shim "pro squat" under the rear of the rear block... what does this do for handling?
Thanks!
inthedust is offline   Reply With Quote
Old 04-20-2005, 06:53 AM   #2348
Casper's Avatar
The drilled piston is when you take a 60 or a 57 piston and you ream the holes out to drill #56 size. The molds used to make the piston do not always get the holes the right size. The drilled 56 will actually give you a little more pack then the standard 56. Racers edge makes some really nice finger drills which make this process much easier but all you need is a numbered drill bit and you can hold it with a pair of pliers.
Old 04-20-2005, 11:18 AM   #2349
KJ - Silvers give more steering but grab ruts more. I've never needed more steering? haha
www.liverc.com
Old 04-20-2005, 02:33 PM   #2350
dkj-M3's Avatar
thx bra, looks like I need to pick up some silvers.
Old 04-20-2005, 06:09 PM   #2351
Davidka's Avatar
Trader Rating: 75 (100%+)
I have found that different brands of shock oil have different actual thicknesses then the "wt" rating indicates (for example: Losi tends to act like oil 5wt thicker than Associated). Do you know how Trinity silicone compares to Losi?
Old 04-20-2005, 10:07 PM   #2352
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
I've never run AE oil....the Losi stuff is amazing, and I am a big fan of the Trinity oil.... I don't know if there's much of a difference between those two though.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 04-21-2005, 06:29 AM   #2353
beidle99's Avatar
I have been replacing all of my Trinity Oil with AE oil, I have heard that Trinity oils are about 2.5 wt off, to the lighter side, from the bottle lable.
I like the AE oil, but I may switch to Losi oil b/c my LHS started getting the Losi oils in.
beidle99 is offline   Reply With Quote
Old 04-21-2005, 05:26 PM   #2354
How often do you clean your clutch shoes??
And how do you clean them??
Dave mac
D Mac is offline   Reply With Quote
Old 04-21-2005, 05:53 PM   #2355
Trader Rating: 27 (100%+)
D Mac, what's up dude? Haven't heard from you in awhile. I just broke in my 1/8 scale. Race the gt and a K3 this summer.
jbrow1 is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
