Old 01-15-2005, 08:01 AM   #1936
Casper's Avatar
Trader Rating: 33 (100%+)
Originally posted by Aaron Waldron
Just move the rear hubs to the upper holes..that'll get rid of on-power steering FOR SURE.
Can I borrow some of that steering, by chance? haha
If you have any pieces of the broken arms, save 'em.
For the too much steering I put bomb one foam in the front tires. I think it may have been too much support in the front tire. I was thinking about lowering the rear hubs to see what that does. I have to find a bunch of washer and a longer ball stud first though!
Why should I save parts? It is still all attached to my truck! Since I did not have parts to fix it at the time I left with it broken!
Casper is offline   Reply With Quote
Old 01-15-2005, 11:40 AM   #1937
Trader Rating: 27 (100%+)
Originally posted by Sgt_Morrow
We just got done porting and polishing my .12 CV about two hours ago. I got the durtrax ABC piston for 20 bucks at tower hobbies. I got one tank through is and got to go back outside to finsh breaking it in but it's like 23 degress out side. Im about too frezze my butt off. But the Big race is tomorrow so you got to do what you got to do.
I forgot to add I don't bother breaking in the cv .12 stock sleeve or the duratrax one. I've been told by some pretty smart fellas it doesn't need it as neither sleeve is a chromed sleeve. I've do take it easy for a tank or two but that's it, and I've got good lifespan from them. And they do run when ported!!
And the aluminum foil is for when it's so cold you can't get the thing past 170 no matter how much you lean it! Ya, it's really to cold to hold the transmitter. I just need a nitro "fix" now and then.
jbrow1 is offline   Reply With Quote
Old 01-15-2005, 12:19 PM   #1938
GregH's Avatar
Send a message via AIM to GregH
I've heard the same thing about heat cycle and general break-in not being needed.
GregH is offline   Reply With Quote
Old 01-15-2005, 02:17 PM   #1939
Trixter's Avatar
Aaron:
I race my Losi trucks at the track in Klamath Falls, Oregon. The track surface is like running on a wet beach. The top 1/16th of an inch gets a little dry but under that the sand/volcano ash material is damp. The traction is unbeliebable. In Stock I run my MF1 with an almost box stock setup. I have pulled out all the inner baering covers, run plastic diff halves (with titainium sleeves) and aluminum dog bones. I have been trying to have better corner speeds. I know that you don't change much in springs and shocks etc, but what camber settings will help me? Like I say the traction is a 9 or 10 on this track. I've been running Silver Step Pins in the rear and Silver Directionals in the front. All have stock foams in them.
Slash 4X4, Bone stock and trying to keep it that way.
PRO MATCH BATTERIES.....THANKS JEFF !!
Trixter is offline   Reply With Quote
Old 01-15-2005, 02:19 PM   #1940
dkj-M3's Avatar
Casper, you could have tried moving to the short arms in front to take some steering away, or did you try it.
dkj-M3 is offline   Reply With Quote
Old 01-15-2005, 05:09 PM   #1941
Send a message via AIM to driftingking05 Send a message via Yahoo to driftingking05
Default RC18T
hey aaron my name is justin and my dad bought me an rc18t and i cant remember where i heard this but i heard that some of the mini t bodies will fit on the 18t and if there is any modifications i need to do to the truck. I also have one more thing for the people who own an RC18T could you let me know how you keep the rocks and pebbles from coming up through the motor openning on the bottom of the chassis cuz i put packaging tape on the whole bottom of the chassis and i just wanna know what you guys put. thanks.
driftingking05
driftingking05 is offline   Reply With Quote
Old 01-15-2005, 06:35 PM   #1942
Sofast-NT's Avatar
I got my parts last wed. & thur. for my ad2 All i need now is rear arms.Have any of you got your parts yet.
Sofast-NT is offline   Reply With Quote
Old 01-15-2005, 07:26 PM   #1943
Casper's Avatar
I only got to run it for like 3 tanks. I have not changed anything on the setup yet. I will start trying things soon.
Old 01-16-2005, 10:49 AM   #1944
Hey Aaron. Good job racing for 2nd yesterday at Sun Valley. That was fun to watch. Is the fade that you're currently running on your AD2 body the new thing or are you waiting to have one painted in your normal paint scheme? Who paints your bodies?
Brownie is offline   Reply With Quote
Old 01-16-2005, 11:10 AM   #1945
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Learn me this Aluminum Foil thing.
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 01-16-2005, 11:42 AM   #1946
The aluminum foil thing is easy. If it's super cold outside but you want to run it anyhow, just wrap some aluminum foil around the head of the motor. Keeps the air from blowing thru it, and will let the engine retain some heat. I don't do it much, b/c if it's that cold, my fingers start to hurt anyhow.
Old 01-16-2005, 11:50 AM   #1947
Casper's Avatar
Just take some alum foil and wrap it around the head of the engine. This reduces the efficiency of the fins on the head and does not allow the heat to escape thus get the temp up on the motor. If you cannot get the engine up to temp and running good you can use this trick but it has to be pretty cold to need it.
Old 01-16-2005, 02:52 PM   #1948
Default Aaahhh...I get it!
Thats really cool.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 01-16-2005, 05:26 PM   #1949
Sofast-NT's Avatar
Aaron can you post a pic of your ad2 with the body on.
Old 01-16-2005, 05:28 PM   #1950
Sofast-NT's Avatar
Aaron is it the trinity alum. front pivot block better than the ad2 pivot block?
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
