Old 05-09-2004, 12:39 PM   #181
KINGZJ's Avatar
Send a message via AIM to KINGZJ
It all really depends on what you mean by "speed" if you want take off speed or top speed. For better take off speed use the largest spur gear that you can use to still get your gearing. for top speed use the smallest spur you can to get your gearing.
KINGZJ is offline   Reply With Quote
Old 05-09-2004, 01:15 PM   #182
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
Post help
yes i want top speed but want it kill my battery fast
nitro kid is offline   Reply With Quote
Old 05-09-2004, 01:23 PM   #183
KINGZJ's Avatar
Typically the more "power" the motor has the more amp draw it will pull so yes thier is a trade off to go faster you will use more battery but you should be able to find a happy compermise
Old 05-09-2004, 01:41 PM   #184
Post help
ok give me a good gear /pinion to use for speed but do not take to much battery
Old 05-09-2004, 02:03 PM   #185
warpig's Avatar
it seems every motor has a "sweet spot" where it just rips.. you may have to gear down to obtain this.. you may have to gear up.. you just have to experiment..
the chameleon 2's sweet spot is when you over gear it by around 3 teeth.. very odd.. but it works well
warpig is offline   Reply With Quote
Old 05-09-2004, 02:09 PM   #186
Post help
i'am runing 88/22 so what will be over gear from there and will i have good speed
Old 05-09-2004, 02:47 PM   #187
Jack Smash's Avatar
Trader Rating: 29 (100%+)
We need to know what you internal transmission ratio is to give you any help.
Jack Smash is offline   Reply With Quote
Old 05-09-2004, 03:03 PM   #188
Post Help
it 2.66
Old 05-09-2004, 03:03 PM   #189
Post help
2.66 2.1
Old 05-09-2004, 03:30 PM   #190
Brandon R's Avatar
im gonna flatten the battery bars...i did some measuring and they will fit just fine by doing that...thanks
Brandon R is offline   Reply With Quote
Old 05-09-2004, 03:46 PM   #191
Post help
it 2.66
Old 05-09-2004, 05:50 PM   #192
warpig's Avatar
you really just need to experiment..
Old 05-09-2004, 06:00 PM   #193
Post help
ok any more guy have any more info
Old 05-09-2004, 06:55 PM   #194
warpig's Avatar
Default Re: HELP
Originally posted by nitro kid
how would you gear a chameleon 2 19T motor on a small high bite track i have a evader.st i'am runing a 88/22 now what do i need to run i'am looking for more speed and punch with out killing my battery fast i'am runing gp 3300batt need help fast if you can let me know befor 6:00Pm that when i go racing thank
okay.. like I said before.. you can overgear the chameleon 2.. it likes the strain for some reason.. it's your choice.. I personally have never had battery problems doing this on onroad or offroad.. you run 3300 batts.. you should be fine for 5 minutes..
to obtain the "proper" gear ratio is a personal thing.. I can't tell you what is best.. but I know I look for good punch while I'm driving the car to be able to clear jumps and get out of corners fast.. I try to obtain a proper ratio to get to top speed about 60% down the straight away.. if it's topping out right away.. it's probably too low of gear ratio and you need a bigger pinion.. if it never seems to get full speed.. you probably need a smaller pinion..
I adjust one tooth at a time.. right now you have a 22 tooth.. if that seems like it has too much torque and is topping out quick.. put a 23 on.. if it didn't change much put a 24 on.. visa versa..
in the chameleon 2's case I find it to like the overgearing though.. I just push it and push it until it finally just screems.. it will get hot this way.. but it never seems to melt the insulation and has worked for around 14 months of racing.. on and off.. that is a unique case.. I've never seen a motor work like that.. usually too hot means you just ruined a motor..
so, take my advise or not.. it's just what I do.. any other motor I would highly suggest to keep it cool and look for the "sweet spot" where the motor just has lots of torque and top end.. every single motor is different.. my chameleon 2 is different than yours and so on.. that's why I say you need to experiment..
is that enough for you?
Old 05-09-2004, 07:14 PM   #195
Post help
thank for the help guys good job i will let your know how i come out next sunday
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
