Old 01-08-2005, 07:22 PM   #1891
Sgt_Morrow's Avatar
Aaron is this a good motor to run in my MF2 Reedy Spec-19 Quad-Mag motor. I got it really cheap and also what kind of speed control would be a good one to use i plan on racing mod truck with this. Also how does this motor compare to the Novak SS4300 brushless motor performance wise.
Sgt_Morrow is offline   Reply With Quote
Old 01-08-2005, 09:35 PM   #1892
Aaron Waldron's Avatar
That motor will out-power the Novak 4300 but it won't have the output of the modified motors that most people in the mod class will be running. 19T motors are great for learning how to drive with more power after stock, and the Reedy Quad-Mag motor runs really well.
I think Casper has had experience with the Reedy motors? If not, he has at least run 19T..and should be able to pitch in some gearing advice.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 01-08-2005, 10:09 PM   #1893
Casper's Avatar
Trader Rating: 33 (100%+)
I never ran the Reedy quad magnet motor. For 19T I have been gearing 2-3 teeth over stock. The reedy I think is a little more of an RPM motor so start with 2 over what you run for stock!
Casper is offline   Reply With Quote
Old 01-08-2005, 10:15 PM   #1894
There he is :-)
www.liverc.com
Old 01-08-2005, 10:16 PM   #1895
Casper's Avatar
Aaron-- Remeber I was talking to you about the tap handle idea I had. Someone had the same idea and made one. Check out this thread.
http://losibk2.com/forum/viewtopic.p...60abef1548bf62
The front bulkheads are pretty cool too.
Old 01-08-2005, 10:28 PM   #1896
Yeah...nice!
www.liverc.com
Old 01-08-2005, 10:28 PM   #1897
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
i just downloaded the dirt setup for the xxxnt (original not the new one) and noticed that the rear shock piston has drilled checked what size hole has been drilled? thanks for any info.
cmain is offline   Reply With Quote
Old 01-08-2005, 10:36 PM   #1898
The pistons were 60's or 57's that have been drilled out to a 56.
www.liverc.com
Old 01-09-2005, 12:20 AM   #1899
Sgt_Morrow's Avatar
I have a used MF2 and ive never raced electric before what size is the stock pinion and spur gear so i will know what to start with.
Old 01-09-2005, 12:30 AM   #1900
The truck doesn't come with a pinion gear brand new, so it's hard to tell what you ended up with after buying it used.
The stock spur gear is an 86 tooth.
www.liverc.com
Old 01-09-2005, 12:35 AM   #1901
Sgt_Morrow's Avatar
I have a 21 tooth pinion gear do you think that would work good to start out with
Old 01-09-2005, 12:53 AM   #1902
Default Kyosho 777
Aaron I don't want to ask it all again so can you read my question in the Kyosho 777 thread? Thanks
Danger Dietrich is offline   Reply With Quote
Old 01-09-2005, 02:31 AM   #1903
morrow - That's probably too tall. I'd start with a 18 or 19 and work from there.
pie8man - Probably one of the best things you can do is add a little bit of rear toe-in. Try giving your car a little more droop as well to calm things down.
Someone posted two good setups on the 777 thread for you.
www.liverc.com
Old 01-09-2005, 02:40 AM   #1904
Sgt_Morrow's Avatar
Thanks for all your help Aaron
Old 01-09-2005, 06:31 AM   #1905
t4usee's Avatar
Also you can read into the back of the manual for more information about setups and what effects adjustments make on the truck. They reccomend 19-21 tooth pinion gears.
We have just purchased a MF2. We have been racing a T4 with good results but the Losi truck is hard to beat, so you know the saying "if you cant beat'em join'em"
I like the way the truck went together especially the front end steering componets. Another would be something as simple as the alluminum shock eyelets. The only complaint I have, which is really minor is you have to do alot of trimming on the parts to remove burs. But if you care for how your vehicle goes together you dont mind doing it.
Keep Up The Good Work Aaron This thread has turned into a full time job for you
Team Fusion
Team Tekin
BKPaintwrks.com
t4usee is offline   Reply With Quote
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
