Old 05-07-2004, 07:29 PM   #166
Brandon R's Avatar
nahhh he dont hate ae just runs losi. Hell he was helpin associated driver out not too long ago! sportsmanship at its finest helpin another brand car person out!
Brandon R is offline   Reply With Quote
Old 05-07-2004, 08:08 PM   #167
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I just like busting his chops a little.
KINGZJ is offline   Reply With Quote
Old 05-08-2004, 01:55 AM   #168
Aaron Waldron's Avatar
Brandon - What style pack are you using?
Team Associated - Most of the team drivers use a basically stock Factory Team truck. As kingjz said, taking the aluminum arms off will help in the handling department, and will make the truck more durable.
I'm not a real fan of the K&N filter, but that's my opinion. I use the Ofna 1/10-sized air-filters, which are down-sized 1/8th scale filters, and they work really well. The stock filter that comes with the truck works great as well.
As far as shocks go, some of the team guys run Progressive Piggybacks on their shocks, or simply use Yokomo shock bladders (AE uses them in their TC shocks as well). They will make the shock easier to build, and a little more consistent.
From what I've seen, the Pro-Line GMC Sierra body is the best handling one available for it as well.
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 05-08-2004, 05:55 AM   #169
warpig's Avatar
you can also use HPI shock bladders.. they work very well
warpig is offline   Reply With Quote
Old 05-08-2004, 06:45 AM   #170
KINGZJ's Avatar
I use the yokomo shock caps with the bleeder screws. You can get 2 of them for $3.
The bladders work also but they add more positive pressure to the shock and you will have to compensate with shock oil weights.
You can also drill the caps and add a fitting and run a piece of fuel tubing between the shocks, fill the tubing with oil and over pack the shock with oil, it works as a poor mans progressive shock system. The gs fuel tubing seems to work the best its the most flexible.
I have played with all the shock setups I could think of and many setups from others and I have come up with using the yokomo caps and mip blue shock o-rings as bieng the best shock for the GT.
Old 05-08-2004, 07:22 PM   #171
I think Jared was only using the piggybacks on the front of his truck this weekend.
www.liverc.com
Old 05-09-2004, 12:22 AM   #172
Brandon R's Avatar
they are the integy 3300's i found some on epay pretty cheap so stole em...i put em together with deans 3.0 and its like the tray needs to be .050 wider and they would fit just fine
Old 05-09-2004, 04:18 AM   #173
Ybakoff's Avatar
HI all.
Just a quick one for the pro's.
I just got a new truck. Sorry not a Losi.
But I ran it a couple of times. No problems. Then I changed to a p94 motor. And it was like I had a radio problem with no control. 1st corner with a few cars in front and me on the inside. Flat out. Luckily I missed all them but not the fence. And no I wasn't living up to my user name as first thought.
The only thing I changed was the motor. What on a motor can cause this problem. And How do I fix it.
Thanks Heaps.
Ybakoff is offline   Reply With Quote
Old 05-09-2004, 11:06 AM   #174
Brandon - It may seem like a tight fit but they should make it in there with a little coaxing. Have you tried flattening the battery bars at all?
ybakoff - Did you solder the capacitors on the motor? I never ran one of the P-94 motors, only the D5-D6 style endbells with the circuit board capacitors.
www.liverc.com
Old 05-09-2004, 11:40 AM   #175
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
Post HELP
how would you gear a chameleon 2 19T motor on a small high bite track i have a evader.st i'am runing a 88/22 now what do i need to run i'am looking for more speed and punch with out killing my battery fast i'am runing gp 3300batt need help fast if you can let me know befor 6:00Pm that when i go racing thank
nitro kid is offline   Reply With Quote
Old 05-09-2004, 11:50 AM   #176
warpig's Avatar
over gear the chameleon 2.. it runs well that way.. this is not a joke.. it may get hot.. but it works and I've been running one over geared along with a ton of others... no failures yet.. it's an amazing little motor
Old 05-09-2004, 11:57 AM   #177
nitrokid - I would start at 20/88 and work your way from there.
www.liverc.com
Old 05-09-2004, 12:00 PM   #178
Post Help
Hi so what gear do i need and what pinion do i need and will it kill my battery fast i'am open to all info guys
Old 05-09-2004, 12:14 PM   #179
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Deans 3.0 bars stick out a lot farther then any other battery bar. Switch those out with some Trinity or Orion bars and your packs will fit fine.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 05-09-2004, 12:24 PM   #180
Arrow help
do you have any more info on how to get speed with gearing
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
