Old 11-10-2004, 11:51 PM   #1486
Aaron Waldron's Avatar
LOL..it's the old truck with a few of the new parts on it. I got my AD2 bodies and have already got them back from the painter, now just waiting on the truck...
Aaron Waldron - LiveRC
www.liverc.com
Aaron Waldron is offline   Reply With Quote
Old 11-11-2004, 07:11 AM   #1487
dkj-M3's Avatar
A-dub are the new bods out yet, I need to get a few to skipgear.
dkj-M3 is offline   Reply With Quote
Old 11-11-2004, 08:39 AM   #1488
TigeRyan's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to TigeRyan
Quick question, I am running a T3 and I am having problems getting it to turn in, it pushes real bad, to the point where I am loosing alot of time in every corner...
I am running proline edges and holeshots in the rear, green springs all around and 35 weight oil, I've tried all the possibly front shock position combos with no success, I have lower the front end and that did not help any either, could I change the battery position, could that help any, I would assume I would move them back so that more weight would be available to transfer forward, or am I wrong, anything else I could try, it I could get this thing to turn I would be golden....BTW: I am running a 19 turn motor and it is on a fairly hard packed surface, indoors....
SixFootTiger Cell Phone R/C Calculator - http://cell.sixfoottiger.com -
Android Marketing Place - R/C Calculator (https://market.android.com/details?id=com.sixfoottiger.andoid.rccalc&feature=search_result)
TigeRyan is offline   Reply With Quote
Old 11-11-2004, 08:57 AM   #1489
Make sure your servo is up to snuff. Trying to get a truck to whip around corners with a poor servo isn't going to happen.
Moving your battery forward will definitely help. Check www.rc10.com for setup sheets for the T3, I'm sure they still have a few there.
www.liverc.com
Old 11-11-2004, 09:01 AM   #1490
Dustinkeys's Avatar
Aaron, Put my drake kit togther and it worked great, went to a big race here and tqed. My brakes seem to have faded ever since, my question is how do you adjust the linkage to get more or less brake?
Dustinkeys is offline   Reply With Quote
Old 11-11-2004, 09:22 AM   #1491
Look on the brake rod. The collar in the back adjusts drag brake, the one in the front does full brake.
If it worked great out of the box, make sure your disc isn't glazed over; if so, rough it up with some sand paper or a hobby knife, or replace it (they will get worn and noticeably skinnier).
www.liverc.com
Old 11-11-2004, 10:28 AM   #1492
TigeRyan's Avatar
Aaron,
Servos up to the task HiTec 945 hi torque....I will try moving the batteries and see what that can do and will checkout rc10.com for setup sheets...
if I unbalance the spring weights, IE: less spring in the rear, what will be the end result?
thanks
Old 11-11-2004, 01:04 PM   #1493
Sofast-NT's Avatar
Aaron,Whenever the ad2 arrives will the parts be availible withit?
Sofast-NT is offline   Reply With Quote
Old 11-11-2004, 05:09 PM   #1494
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
WO...I just had a great idea, although it would never work in racing situations, but it would be fun to try.... take a sheet of 1000 grit sandpaper the exact shape of the brake pad and glue it directly to the metal pad. Your car would stop like none-other, but the disk would wear out way before the 30 minute mark....the thought was there though!
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 11-11-2004, 05:16 PM   #1495
Please forgive me for post hoarding.....700!!YEEHAW
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 11-11-2004, 05:17 PM   #1496
Send a message via ICQ to cmain
TigeRyan
changing the front steering blocks from 30 degrees of caster to 25 solved my steering issues the truck is much more aggressive entering the turns.
cmain is offline   Reply With Quote
Old 11-11-2004, 05:37 PM   #1497
TigeRyan - If I remember correctly, most of the AE guys ran softer springs in the rear of their T3's as opposed to the fronts. Softer springs often help the car find straightline traction.
www.liverc.com
Old 11-12-2004, 07:47 AM   #1498
dkj-M3's Avatar
TigeRyan, I'm not sure on the T3 but on my losi too much front toe-out caused it to push badly in the corners.
Old 11-12-2004, 08:37 AM   #1499
TigeRyan's Avatar
Thanks everyone for all the suggestions, have made a list of things to try, gotta get to the track early and try them one at a time and see if I can find some initial turn in....straightline the truck is real stable and fast, maybe one of the fastest on the track, but man does it stink around the 180's....if I get that dialed in I will be golden....
Again, I appreciate everyones help and suggestions, I will post how they worked out....
Old 11-12-2004, 12:08 PM   #1500
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Hey Aaron, when does Hemet race?
Loaded Serpent 710. Aaron Burans Previous Car! NitroMaxx3.3 R/C Items: For Sale/Trade 2 05-03-2008 05:42 AM
Aaron Bomia is an Excellent Seller! Luckyman4 Buyer/Seller dispute and Feedback discussion forum 0 06-25-2004 09:23 AM
AARON BOMIA = Great Trader Mart42 Buyer/Seller dispute and Feedback discussion forum 1 02-05-2004 08:15 AM
