Old 03-13-2010, 07:42 PM   #16
Trader Rating: 24 (100%+)
Originally Posted by dreaux View Post
i did motto. Aluminum tape. lots of it. I am taking the cooling head off completly and screwing the head button straight to the engine case. then i can put the tape straight on the block and head button.
Just an idea i had. Do my needle settings sound far off? they don't to me. I will lean it out to within about a hour or two to my final setting.
which i am a hour away from right now.
do you guys just lean your hsn first? or both? should i not even touch the lsn now? what kind of tunning steps do you take?
be careful doing that. One time a friend broke a head off(all but bottom fin) in a race and temps were aroung 45 and that thing went hot fast.
What is your outside temps?>
Owner of the Speed Shop: A race prep shop for anything related to 1/10 and 1/8 off road racing. Check us out: https://www.facebook.com/pages/The-Speed-Shop/382214705269137?ref=bookmarks
ABURTON is offline   Reply With Quote
Old 03-13-2010, 08:16 PM   #17
Trader Rating: 47 (100%+)
Originally Posted by ABURTON View Post
We could handle this for ya at the Speed Shop and put it on a bench in a controlled enviroment ant have it at operating temps yet still letting it run rich. It's a very safe and effective break in. The more you run it like that the worse things will be.
My email is alanburton20@gmail.com if I can help you in any way.
dreaux, maybe you should send the engine to Alan for
a proper break-in. Leave the carb needles where you
have them set now, box it up and send it to him, along
with your phone number. I'm sure he would gladly let
you know how far off you were on the adjustment and
give you some pointers. Please don't give up on burning
nitro and turn your car into a flashlight. Most of the guys
that offer engine service and modding would gladly help
you with getting your engine right. They all love to talk
about these nitro belching little engines. Good luck.
rageworks is offline   Reply With Quote
Old 03-13-2010, 09:04 PM   #18
outside temps were mid sixty's. i need to tune it up obviously. the plug was soaking wet when i took it out.
Besides if i don't get it right now then it's ruined any way, like some of the other motors i have had. I good break in is great and all but if it's not tuned right it won't matter. A bad tune will destroy pinch regardless.
now i am going to tune my high end and get it close to full power. My problems come when i try to lean my high and low at the same time.
Will my idle raise if i lean out the hsn??? It's very fat right now and i don't want to mess with the lsn until i get the hsn right. At the same time, it wont idle with out me setting the trim to keep the throttle open it's too rich, but i don't want to lean out the low end just to get a better idle right?
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-13-2010, 09:26 PM   #19
Jaz240's Avatar
Trader Rating: 52 (100%+)
I think you just have a bad temp gun..try cleaning it, or going with exergen..Do a test, Boil water and temp it with your gun, it should be at 202-210 degrees
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 03-13-2010, 10:03 PM   #20
MotoGod's Avatar
Trader Rating: 112 (100%+)
Send a message via AIM to MotoGod Send a message via Yahoo to MotoGod
During break in....I really only mess with the LSN for the most part. At least for the first few heat cycles. I'm not revving the engine anyway....so the LSN is doing the brunt of the work.
Just send to Alan...he'll get it spot on for ya ;-)
Scott Pouliot
Current Race Rigs: TLR 8ight 3.0/3.0E/3.0T/22/22-4
Thanks to my 2015 Sponsors: LutzRC, RadioPost, AKA Tires, RC Addition Products, Nitro Pro Fuels
MotoGod is offline   Reply With Quote
Old 03-13-2010, 10:53 PM   #21
Trader Rating: 21 (100%+)
105 degrees Celsius = 221 degrees Fahrenheit, which is about right for an engine that is quarter turn rich than a race tune.
switch your temp gun from C to F!
TopGearRC is offline   Reply With Quote
Old 03-14-2010, 07:45 AM   #22
Trader Rating: 61 (100%+)
+1 good observation ..and then send it to alan burton at the speed shop ..get it off to a good start
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 03-14-2010, 08:29 AM   #23
all is well, i overreact to everything.
I guess because a mistake can cost hundreds of dollars
Mugen
Old 03-14-2010, 09:12 AM   #24
My Alpha plus S852 still has alot of pinch after over a gallon of fuel. Don't worry about the pinch.
Stick with it fella, you'll get there.
Flipfly is offline   Reply With Quote
Old 03-15-2010, 06:21 PM   #25
cordarrow's Avatar
Trader Rating: 17 (100%+)
Originally Posted by TC3
I run three tanks on the starter
box at a rich idle keeping the temps about 220 degrees using an electric engine warmer.
I heat cycle....but I like the sounds of this when getting started...didn't think to keep the gun on it for a tank or two of rich idling...thoughts?
cordarrow is offline   Reply With Quote
