Old 03-11-2010, 04:23 PM   #1
Default what is the easiest way to tell if the rear engine bearing is bad?
Ok, even a new bearing (tko's anyway), have a very small amount of back and forth play. I know some of the engine bearings i have changed not only have more back and forth play but side to side play as well.
So, i have some ceramic bearings with a couple gallons on them, but just want to know if there was a easy way to tell they are fine. Just to make sure.
thank you for anybody who answers
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 03-11-2010, 04:36 PM   #2
mrbusta's Avatar
Trader Rating: 20 (100%+)
Send a message via MSN to mrbusta Send a message via Skype™ to mrbusta
flame outs
and strip the engine down check the play and the grit feel
no set fuel mileage at least thats how i do it
SHAYNE/MONSTER ENERGY/BETA TYRES Australia
Thanks to www.wprcracing.com/P.N.D Paint works
81/MUGEN Mafia
RIP BUSTA BB ANGEL
mrbusta is offline   Reply With Quote
Old 03-11-2010, 04:49 PM   #3
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
pull the crank, stick your finger in the back of the case, press against the bearing and spin, if its gritty it's done.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 03-11-2010, 06:08 PM   #4
KK-racing's Avatar
Most noticeable is Noise - some kind of unusual high pitch noise when u fires it up & when running.
My ride - Mugen / Ninja / M11 / Sanwa(Airtronics), very close 2 yours !
Do 'IT', with a DUREX (safely) !!!
KK-racing is offline   Reply With Quote
Old 03-11-2010, 07:09 PM   #5
i am putting a new con rod on a new vspec P/S. I am about to smash the darn thing with a hammer. I have never had this much trouble putting a con rod on before. but i have only done ninjas, is the vspec different or something? I have the tabed ninja clips. Any secrets? I usually can get it in with my finger nail but no matter how hard i try i can't get it.
Some one help before i start using sharp metal objects to pry it in there.
Why is this so hard?
And why the $#%^ can't you buy a P/S with a con rod on it? I already have a couple extremely small scratches from my finger nail and or clip. This sucks
SOmeone please help me.
Mugen
Old 03-11-2010, 07:26 PM   #6
bump for some help.
Mugen
Old 03-11-2010, 08:18 PM   #7
mrbusta's Avatar
bump for some help.
MY FRIEND BE PATIENCE
yea dude i hear ya its frustrating
i found if use tweezers and pillow case cut holes for ur arms pop ur head in there with motor and do it in there so u dont loose the clips make sure no one sees u or they may think kkk lol good luck and if that dosent help fuck of to do something else clear ur head and come back that helps with the frustration due good luck
81/MUGEN Mafia
RIP BUSTA BB ANGEL
Old 03-12-2010, 12:35 AM   #8
MontanaMaxx's Avatar
well they do have the v spec speed p/s/r assembly cheaper than getting the rod and p/s seperately
MontanaMaxx is offline   Reply With Quote
Old 03-12-2010, 03:15 AM   #9
yeah, i got it. I have zero patience.
Mugen
Old 03-12-2010, 03:29 PM   #10
j_blaze14's Avatar
Trader Rating: 34 (100%+)
pull the plug and turn it over with the flywheel. put the bottom of the case to your ear and listen. you'll know if its bad. i also heard a screw driver works too, put the tip on the head with the engine idleing and put the handle in your ear.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 03-12-2010, 09:55 PM   #11
fukitol's Avatar
i found if use tweezers and pillow case cut holes for ur arms pop ur head in there with motor and do it in there so u dont loose the clips make sure no one sees u or they may think kkk lol good luck and if that dosent help of to do something else clear ur head and come back that helps with the frustration due good luck
little spelling help or edit for ya
is that fast, can i drive it, how much do they cost
fukitol is offline   Reply With Quote
Old 03-12-2010, 10:00 PM   #12
If the rod won't go onto the crank pin easily chances are your rear bearing is not seated properly.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 03-13-2010, 01:30 AM   #13
Come on man. I had to try and read this four times befor I kinda' got it.
The Working Man is offline   Reply With Quote
Old 03-13-2010, 09:46 AM   #14
Dano628's Avatar
I use a fairly good sized cardboard box on its side with a towel inside . A tool I made out a plastic drink stirrer ( sanded it down to a very small screwdriver looking tip) . I also keep two bags of wristpin clips at hand when I'm doing it .Like busta said if you run into problems take a break and come back to it . It's amazing how many times I have struggled with something taken a break and gone on to something else then come back to it and completed the task no problem .
Dano628 is offline   Reply With Quote
Old 03-13-2010, 06:27 PM   #15
mrbusta's Avatar
hahahaha yea i put it in i was hopeful the spell check would fix
sorry to offend but im sought of blunt
81/MUGEN Mafia
RIP BUSTA BB ANGEL
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 03:19 PM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 05:01 PM
rc10 gt loose sheetmetal2 Nitro Off-Road 17 08-12-2007 05:23 PM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 08:19 PM
