Old 03-10-2010, 08:40 PM   #1
Trader Rating: 26 (96%+)
Default Changed fuel and problems
I have gone to trying out for the first time nitroX 30% with 10%oil on my losi truggy 2.0 stock .28 motor.
I reset low and high needles to stock recommendations as per manual and both are set at 2 ½ turns out from bottom.
The motor fires up almost straight away so I let it idle for it to warm up but after about 20/30 secs it starts increasing speed by itself and keeps on climbing towards max RPM.
I kept an eye on the carby throttle and did not see it open/move to create this quick increase of RPM.
Suggestions please in what I need to do.
RustyOne is offline   Reply With Quote
Old 03-10-2010, 08:57 PM   #2
What fuel did you have before? And what engine do you run exactly??
Pro24888 is offline   Reply With Quote
Old 03-10-2010, 09:07 PM   #3
The fuel before was one that the local hobby store had and most guys said get something better,so I did.It was 20 % and 16 % oil.
Last time an experienced driver tuned it for me.
This is the Losi 454 engine they supply as RTR.
Old 03-10-2010, 09:08 PM   #4
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
Check for leaks
Add a shim to the head
Go 1 step cooler plug
boomgagem is offline   Reply With Quote
Old 03-10-2010, 09:11 PM   #5
I'm using a O.S. number 8 plug
Old 03-11-2010, 08:43 AM   #6
You have to retune - - - -
geejay is offline   Reply With Quote
Old 03-11-2010, 09:01 AM   #7
NuthinFancy91's Avatar
If it idles up really really fast then check your idle first. If it idles down then idles up, could be a rich low speed.
-Bo
Johnson Racing Team #94
Blue Groove R/C Apparel
Rccna Racing Team
Team Losi
NuthinFancy91 is offline   Reply With Quote
Old 03-11-2010, 09:08 AM   #8
that is to be expected, every time you change fuel (different, nitro, oil content or brand) you will have to retune.
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 03-11-2010, 09:10 AM   #9
especially from 20 to 30 percent
1+
Old 03-12-2010, 07:13 AM   #10
Thanks guys i'll give it a go tomorrow and report back
Old 03-12-2010, 08:26 AM   #11
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
make sure that plug is the correct length! Some of the OS plugs have long or short bodies. if you used a long body in a short application you'll increase compression drastically, and if you use too short of a plug in a long body app, then your decreasing the compression majorly. this is why you should buy and use the plugs suggested from the manufacture.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 03-12-2010, 08:52 AM   #12
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
+1 on what joe sayed. but also sounds like a air leak at bearing. the motor is warming up and metal is expanding causing airleak. also check to make sure your not getting airbubls in your fuel line from faulty line or tank
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 03-12-2010, 08:58 AM   #13
houston's Avatar
Trader Rating: 91 (100%+)
guaranteed it is wayyyyy too lean bro !!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-12-2010, 09:16 AM   #14
losi_racer's Avatar
Trader Rating: 25 (100%+)
thats what i was thinking
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Offroad Nitro Engine Forum 97 01-07-2014 08:43 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
BAD AUSTRALIAN AMAIN FUEL KILLS ENGINES rc skyline Nitro Off-Road 215 11-18-2009 05:50 AM
Race Revo RTR just need fuel and driver cappa R/C Items: For Sale/Trade 31 01-30-2005 10:33 AM
