Old 03-10-2010, 04:46 PM   #1
Trader Rating: 119 (99%+)
Default proline foams
what is the difference in the 2 somewhat new proline foams the Blue closed cell foam and the black evo foam?
i have been out of the loop on proline foams with just running AKA foams in all my tires. but would like to know what is up with these new proline ones
skoalisbad4me is offline   Reply With Quote
Old 03-10-2010, 06:27 PM   #2
mblgjr's Avatar
Trader Rating: 86 (100%+)
Of the two, you'd want to go with the Black Evo2 foams.
They're a little softer and have more compressability to them.
The PL Blue's are very dense. I only intend on using the 1-set I have at a smooth,indoor grooved track. I wouldn't use them on any outdoor track.
I emailed PL when they came out and the response was that they had better success using the Evo 2 black for the most part and that it was better on rough tracks.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 03-10-2010, 06:42 PM   #3
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
The Evo2 black foams are also a bit lighter so that's a plus. They are good foams! Super light weight and seem to be a good density.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 03-10-2010, 06:51 PM   #4
how are they compared to the AKA's tho. has anyone compared the two and what are your thoughts? also i acetone my tires when they are shot and the thing i like about AKA's is that you can re-use them. can you do this with the Evo's does anyone know?
Old 03-10-2010, 07:28 PM   #5
They are very close to AKA foams. They are a bit lighter and they are shaped to fit proline tires obviously.
A tip for the acetone deal, if you are doing it just to save the rims and don't care about the tires, cut the foams out of the tires before you acetone them. Saves them from a lot of unneeded chemical exposure.
-Koby Kubrin-
Old 03-10-2010, 08:09 PM   #6
usually i do that. but sometimes i have to dismount good tires due to cracked rims as i use to run alot of rulux rims and wabash rims and those crack sometimes
ProLine foams HookaMega Nitro Off-Road 133 09-08-2011 02:13 PM
Proline foams hobdog Nitro Off-Road 23 12-28-2008 09:07 AM
Proline foams for 4wd holeshots. Cut or not? Dasupacat1 Electric Off-Road 26 11-21-2007 10:57 AM
