d8 bearing
Old 03-11-2010, 06:02 PM
Default d8 bearing
so i am planning on purchasing a new d8 and i am wondering what bearings i should put in it i am currently debating between ACER and ready rollers any suggestions?
snoninja93 is offline
Old 03-11-2010, 06:13 PM
I ran the kit bearings then replaced them with AVIDS.
Alan D. is offline
Old 03-11-2010, 06:32 PM
wfo
wfo's Avatar
Location: SO. CAL. Thunder alley, revelation raceway The Dirt -Perris RIP OCRC
AVID......
wfo is offline
Old 03-11-2010, 06:35 PM
Shoaf85's Avatar
Trader Rating: 19 (100%+)
Answer-RC! Check out http://www.twisted-rc.com/bearings_11.html for a complete bearing set for your D8 at a great price!
Shoaf85 is offline
tkge's Avatar
Trader Rating: 123 (100%+)
Avid is all I use, you cant beat the price and shipping is really fast. David is a great guy and racer, so he knows what works!!
http://www.avidrc.com/
Tim
tkge is offline
Old 03-11-2010, 06:41 PM
bcarter007's Avatar
Trader Rating: 96 (100%+)
Default kit
run the kit bearings till they need replaced then run avid
avidrc.com
bcarter007 is offline
Old 03-11-2010, 06:44 PM
Originally Posted by wfo
AVID......
Pleural
Alan D. is offline
Old 03-11-2010, 07:44 PM
i herd those wear out pretty quick?
Old 03-11-2010, 07:51 PM
Avid bearing , great product. Try them, 1.00 each cant go to wrong.
nothin special is offline
Old 03-11-2010, 07:55 PM
yeah i most likely will
Old 03-11-2010, 07:58 PM
tkge's Avatar
yeah do like bcarter007 said, run the kit bearings for now, order the Avid ones and when you rebuild the diffs and stuff, just replace the bearings then. I ran the kit bearings for a while on my first D8 and they were fine. Just make sure when you order the Avid ones, get the ones with black rubber seals. Also be a good idea to order several sets of clutch bearings to keep on hand since they wear out fast anyway, no matter what brand.
Tim
tkge is offline
Old 03-11-2010, 08:08 PM
thanks will do
Old 03-12-2010, 09:44 AM
rcgeezer's Avatar
You should seriously consider the Answer RC-USA bearings. Excellent bearings at a great price...you can't ask for anything more! As the others have said, run the kit bearings until you begin to do your maintenance, then replace as necessary. I've been using the kit ones for quite awhile with no failures.
rcgeezer is offline
