Old 03-07-2010, 01:48 PM   #1
Send a message via AIM to Cisco904
Unhappy suspension too stiff?
Hey y'all, I'm running a 2.5 nitro rustler, today I broke the shock tower I just replaced, as in this was the first run with it. I have a fairly stiff suspension setup because the truck was having problems bottoming out, now its having problems keeping the rear shock towers in one piece, when I broke the tower I was landing from maybe 2-3 feet in the air, 10-15 foot gap onto concrete/grass at around 35 mph. Am I being to hard on the little truck? I used to beat on it wayy harder then that without a hitch. As always in my threads any positve or neutral input is welcomed, Thanks y'all for reading this one.
-Greg
O.S. .21 Maxx
2.5 Nitro Rustler
88' Traxxas Fiero GTP #766
4x2 Slash
Cisco904 is offline   Reply With Quote
Old 03-07-2010, 06:15 PM   #2
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
depends on what you call stiff suspension if your using the spring to make it stiffer dont. change to a thicker oil or smaller piston hole size. set the springs only for ride height basickly drive shafts level to ground.
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 05-23-2010, 07:39 PM   #3
ele_to_nitro's Avatar
what type of shock towr are you using because you can change how the tower eacts to the landing, oh, and have youtryed changing the shock mounting points?
ele_to_nitro is offline   Reply With Quote
F-103 suspension position ? pope Electric On-Road 7 03-03-2010 02:16 PM
slash suspension dcm0070 Electric Off-Road 11 10-29-2009 01:06 PM
Need some help with suspension setup Uhgg Monster Trucks 7 08-17-2009 11:36 PM
