Old 05-12-2010, 06:47 AM   #121
Losi needs the TP type balance connector. This one should work. I don't know if it is the one you have cause your link didn't work for me.
http://www.amainhobbies.com/product_...ght-Power-Losi
HB Ve8 Tekin RX-8/1900kv T8
HB D8
Team Associated B4.1 Tekin RS/Redline 17.5
Team Associated B44.1 Tekin RS pro/Redline 13.5
fazznick is offline   Reply With Quote
Old 05-12-2010, 07:48 AM   #122
Ananda Robinson's Avatar
Originally Posted by underway View Post
Ace 1015
I went with the 7940's its a lot quicker than the 7955's on lipo
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Ananda Robinson is offline   Reply With Quote
Old 05-12-2010, 07:49 AM   #123
Nick that's the one i purchased no dice
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Old 05-12-2010, 08:06 AM   #124
One thing you can check is if the metal conectors on the balance tap are bent (the metal tabs on the end of each wire). I have had this problem before and used a little screw driver to bend them back. Just do them one at a time because I think those balance wires can short the battery.
HB D8
Old 05-12-2010, 08:11 AM   #125
The losi is a 3 pin female connector the slot on that board is a 4 pin male its not even the right connector at all.
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Old 05-12-2010, 08:25 AM   #126
Weird
HB D8
Old 05-12-2010, 08:25 AM   #127
Weird
tell me about it
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Old 05-16-2010, 03:56 AM   #128
I really like the 7940's over the 7955's for steering night and day difference. Raced at the trophy race at Blue Diamond yesterday, The JL .21 from clockwork's ran flawlessly all day. I made some suggested setup changes and the car sailed into the A main(thanks Dan R and Brian M.) I stopped for gas 4 times in a 20 minute race, I have to figure that pit stop thing out All and all its starting to come together
Losi 8ight 2.0.
Losi 8ight-T 2.0.
Old 05-16-2010, 01:28 PM   #129
trackstarlosi's Avatar
in practice fuel your car and use a stopwatch, start it when u go out and stop it when u run out of gas. the most you should stop in a 20 minute race is twice, around seven minutes and around fourteen. my motor makes 11:00 minutes easialy so i do one pit.
Dylan Elliott
TLR Team Losi Racing / Novarossi / Nitrotane / Spectrum
trackstarlosi is offline   Reply With Quote
