Old 03-01-2010, 03:56 AM   #1
Default LIPO ATE MY BUMP BOX MOTOR!-best replacement
Any ideas on a better replacement? It had a Thunder Tiger 550 in it. I need 1 ASAp I might be going to PNIB Thursday.
JonnyW is offline   Reply With Quote
Old 03-01-2010, 07:01 AM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
the ofna 770 motors are great. check and make sure your pinion will come off the original. You might need to drill the original pinion to fit a new motor. good luck
8&stuff is offline   Reply With Quote
Old 03-01-2010, 07:33 AM   #3
You can get the Ofna with a pinion installed, I know its the same pitch as the AE and Losi belts, they all should be the same.
TLR - Spektrum - Horizon
geejay is offline   Reply With Quote
Old 03-01-2010, 07:48 AM   #4
Send a message via AIM to njballa Send a message via Yahoo to njballa
Great Planes sell a 600 and larger eletricly motor those great and cheap too..
njballa is offline   Reply With Quote
Old 03-01-2010, 03:40 PM   #5
Default Thanks Bros!
I ordered a Ofna 770. Lets hope it will hold up to all the arc welding.
