Old 02-28-2010, 04:57 PM   #1
lsbully's Avatar
Default Air filter for performance
I have a hyper 7 with a Dynamite .21 and the stock air filter looks like
I removed it and installed a filter off a Tmaxx, that looks like
My thoughts before hand were-
- Moving air filter to new location, one that gives the filter fresh air, instead of being tucked near the cooling head sucking in heated air from the heat sink
- Cooler air equals more horse power
- Less bends in air filter hose allows the carb to recieve the air faster and unrestricted, there for not giving the air a chance to warm up.
My question is what do you guys think, what are the pros and cons.
I did notice my temps dropped quite a bit, and cools down more at idle.
Hyper 7 (yeah its old school, but the parts are cheap as hell)
Ofna JL .21
Jammin JP-3
Picco P6TH plug
Byrons 20%
lsbully is offline   Reply With Quote
Old 02-28-2010, 05:07 PM   #2
madweazl's Avatar
I had one like the lower pic on my old RC10 GT and never had any issues with it but I'd stick with the original setup. It has exponentially more surface area and with the vehicle moving, there wont be enough heat soak to make a difference in performance.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 02-28-2010, 05:35 PM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Default A Universal Recommendation
Cage : http://www.prolineracing.com/product...er-317-64.html
Replacement Filters : http://www.lucky7rc.com/product_info...roducts_id=286
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 02-28-2010, 06:04 PM   #4
itsshemp's Avatar
This is the best filter set-up I have used to date. You can also get the pack of filters, and oil which will last you a long time. If you go this route, you will want the Pro-Line oval style, replacements.
Danny Flores
____________
Team Driver for:
Hot Bodies/HPI - Track Star Services - Triton R/C - Alpha Plus Engines - Radiopost - Hemet Competition Raceway (HCR) - Hemet R/C (R.I.P)
itsshemp is offline   Reply With Quote
Old 02-28-2010, 06:21 PM   #5
smb17's Avatar
Send a message via AIM to smb17
smb17 is offline   Reply With Quote
Old 02-28-2010, 07:11 PM   #6
lsbully's Avatar
I appreciate your replies!
Am I right about what I thinking tho?
Ofna JL .21
Jammin JP-3
Picco P6TH plug
Byrons 20%
Old 02-28-2010, 07:14 PM   #7
madweazl's Avatar
I'm going to guess that your results (cooler temps) were a direct result of less airflow from the Traxxas filter system. This effectively richened your a/f ratio giving the results you noticed.
RadioPost
Old 02-28-2010, 07:27 PM   #8
A short airfilter boot will breath better than a long one.
topcat-lll is offline   Reply With Quote
Old 02-28-2010, 07:41 PM   #9
lsbully's Avatar
thats what happened. But is it really less air flow? Same type filter element that comes with the stock air filter.
Ofna JL .21
Jammin JP-3
Picco P6TH plug
Byrons 20%
Old 02-28-2010, 08:39 PM   #10
smb17's Avatar
I've seen people cut holes in the body right where the filter is at to get cooler air. But I'd get the proline filter and the lucky 7 foams. The foams come pre oiled so you can just toss them and always have a clean filter.
Old 02-28-2010, 08:53 PM   #11
madweazl's Avatar
If all else was equal than yes, it has less air flow.
RadioPost
Old 02-28-2010, 09:04 PM   #12
smb17's Avatar
By the way the Tmaxx style filter doesn't have much filter surface area. To me that will clog up quickly.
Old 02-28-2010, 11:12 PM   #13
NitroFreakManHo's Avatar
Send a message via MSN to NitroFreakManHo Send a message via Skype™ to NitroFreakManHo
The best flowing air filter that I've ever used, when clean or dirty, is the stock RC8T filter. This thing flows better dirty than most clean filters I've owned, but, the filters foams are thin compared to other filters, and need to be checked more often . If you want flow, try one.
The Proline setup looks great too!
TEAM TERRIBLES √ 2009/2011 SORRCC Points Series Truggy Champ
CRE Werks B5 powered Serpent 811-T
CRE Nova P5 Powered Serpent 811-B
**M2C**Hitec 7955TG Servos**Buku Clutch
www.apaarchery.com www.skoffroad.ca www.youtube.com/nitrofreakmanho
NitroFreakManHo is offline   Reply With Quote
Old 02-28-2010, 11:32 PM   #14
Frank L's Avatar
Trader Rating: 148 (100%+)
I used the motor saver system for awhile and then went to the Losi 8ight system. Both of the filters are oiled and it has not let me down.
Old 02-28-2010, 11:40 PM   #15
smokinu's Avatar
Trader Rating: 60 (98%+)
im rockin the losi system on my truck now they are great!
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
air filter oiling rules? dreaux Nitro Off-Road 13 06-29-2009 07:42 PM
Air filter protection Edron Nitro Off-Road 10 04-24-2008 07:54 AM
Air Filter DrIfT'R' Monster Trucks 6 04-26-2004 06:22 AM
k&n air filter mrredrsx02 Nitro On-Road 88 12-21-2003 10:12 AM
