Old 02-27-2010, 04:59 PM   #1
czarc's Avatar
Default PIPE FOR OS SPEED WC 2050 OR 2060 IN TRUGGY???
THE TITLE SAY ALL ...THANKS
czarc is offline   Reply With Quote
Old 02-27-2010, 05:15 PM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 02-27-2010, 06:00 PM   #3
cary's Avatar
Trader Rating: 67 (100%+)
Xray XB8 14,AE RC8T3,XB9 13,Kyosho wheeler,Losi SCTE 2.0,+ More
> The Animal,Frank L. Jr. <
~~~~RedRock Hobbies~~~~
cary is offline   Reply With Quote
Old 02-27-2010, 06:02 PM   #4
blade954's Avatar
Trader Rating: 23 (100%+)
blade954 is offline   Reply With Quote
Old 02-27-2010, 06:02 PM   #5
blade954's Avatar
yep great pipe for the truggy, we run it with a V Spec....and will be trying it on the new OS 25 as well in the truggy.....
Old 02-27-2010, 08:17 PM   #6
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
2050 will give more bottom end...
2060 will be a smoother power band...
i run 2050 in truggy and 2060 in buggy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 02-27-2010, 09:12 PM   #7
2tap's Avatar
The guy from the cheese state is right.
Ether will work well. They are a fine tuning option.
2tap is offline   Reply With Quote
Old 02-27-2010, 09:16 PM   #8
Just to throw in a vote, I like the 2060.
-TKO Competition Development-Sidewinder Fuel-
Alan D. is offline   Reply With Quote
Old 02-27-2010, 09:34 PM   #9
Frank L's Avatar
Trader Rating: 148 (100%+)
I have both pipes and in the truggy I like the 2060. The 2050 hits harder onn the bottom but it really chops the top off on the speed engine. The 2050 also sucks more gas. The 2060 pipe is a perfect all around pipe, it's not soft on the bottom at all and it let's the speed engine wind out on the straight. Bottom like is if you try them both you will put the 2060 back on and nevr change it.
Old 02-28-2010, 06:02 AM   #10
Stubbs's Avatar
I'm about to try my truggy out today with a 2060 on my Speed. I've been running the 2050 for the last few times at the track. I'll be interesting to see how it affects the engine. With 13/50 gearing, I seem to be winding out about 1/3 the way down our 200 ft. front straight. Could be the pipe, could be the gearing.
I'm good on the infield, just would like a tad more top end on the straight. If it's still winding out early, but is still strong on the infield, I'm going to jump up to a 14T CB, and see how that works. Hopeully it won't raise temps too much.
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 02-28-2010, 03:59 PM   #11
hambone's Avatar
2050 kills the speed. Go 2060 and you'll not look back. Losi RE10 works real well on speed. More topend than 2060.
Rob Hamm
The Nitro Shop
Bones Motorsports
Answer-RC/TLR/Futaba
Snow Monkey Racing
hambone is offline   Reply With Quote
Old 02-28-2010, 07:11 PM   #12
Stubbs's Avatar
Well, hambone's right....the 2060 was aces in the Speed today. Much smoother power delivery. Still had all the bottom end that I needed for the jumps, but revved out better on the straight.
Next, I'm tweaking my gearing and clutch to get a bit more stall, and just a tick more top end. I think the higher stall will offset the jump from a 13t to 14t bell.
If you're planning to buy a pipe, get the 2060. Then you can try someone's 2050...honestly though, my 2050 is likely to stay in the pit box most of the time. I may put it on if it's really hot and humid, when the engine won't be making as much power period. In those cases, the extra bottom end may be helpful.
Old 02-28-2010, 07:22 PM   #13
Frank L's Avatar
My 2050 saw one race day and then in the box.....
Tamiya TRF 801X 1/8 Buggy! bola Nitro Off-Road 2517 02-13-2017 09:11 PM
