does anyone know how mugen glues their tires on the mspec?
#16
#17
Premounts should be glued from the factory. Proline premounts are infamous for becoming unglued. Last time I knew premounts were hand glued and they way they did it was by dipping a tooth pick in CA glue and running it around the rim and bead.
#19
I think that alot of guys forget that the tire will wick the glue. You dont have to put as much as you think to get them to hold. I (knock on wood) havent had a set come apart on me yet. I just take my time a put in the prep work. What I really want to master is tire balancing!
#20
tire gluing is a cinch, buy the losi tire glue kit, comes with rubber bands, glue and the most ingenious invention, a little tube to apply the glue.
1. put the tire on the rim, and massage it on till you know the foam insert is seated properly. make sure the rubber bead is seated properly.
2. wrap the supplied rubber band around the side your about to glue
3. peel back an edge of the tire, insert glue tube and put a bit of glue in, the tire will suck it in pretty easily. If you do put too much, just rotate the tire, and let the glue flow around the direction your turning, while at the same time your slightly peeling back the tire to let it sink in.
4. do the same thing on all of your other tires, important note, do 1 side at a time. by the time you have one side done on a set of 4 you can go back to the first one and start the process over on the other side. this prevents you from gluing the tire to your fingers.
