mugen mbx6t vs mbx5t
#16
MBX5T's are as tough as nails !
#17
the losi 10t is junk ...save yer cash...i bought one right when they came out (i never touched it after break in)
the d8t is a pretty sick truck for the money....
i also own the mbx5t and its by far the funnest best handling truck i own....i actually installed an old o.s. .21 vg i had sitting forever yesterday and WOW...even the little 2 horse motor gets it moving really well...
a good question (which ive been wanting to ask ) is what parts are compatable between the mbx5t and the 6t
#19
diffs, rear center driveshaft, wing mount a some small plastic spacers etc.
#21
i wonder why people dont just run the 5t diffs in the 6t then...if thats one of the weak links in the 6t
#22
#23
Close but nope they are different too. the center diff is located a little more forward in the mbx6t so the front shaft is a hair too short and the rear is quite a bit too long. The 6t is around 10mm longer than the 5t which throws everything of from the get go. I am running BCE chassis on my 5t's and even with the extra length of the BCE the 6t shafts still dont work. Wish they did but no cigar.
#24
if so then show me part number for front center for MBX6-T
manual says E0202 same as for MBX5-T
rear are e0247 for 6t and e0212 for 5t so they are different of course with 6T being 10m longer
#25
Your right they do share the same part number(which would indicate they are the same). But I am just saying unless the mugen guy at the races handed me the wrong dog bone(possibility) they are different lengths. I compared them side by side on all of the bones to see if he had anything I could use on my 5t.
#26
I love my 6T, its very, very, durable, I am not aware of any diff issues, and havent broken a single arm yet on my 6T, nor have any of our Team Drivers
#27
No diff issue on the 6t.You just need to check them after break-in and add a shim if needed.I didn't do this and ate a diff.No problems since though.
#28
what is the BEC chassis?
#29
chassis made by BCEspeed.com
#30
what about the big bore shocks?
