Old 02-27-2010, 06:38 AM   #1
Default Starter Box Lipo
What Lipo's are you guys running in your starter boxes. OFNA to be specific. I have been using the 90 pound gel cell and its getting old and needs replaced. I just don't like the power of it. I used a starter box from someone else the other day with lipo and it had a lot more kick to it. Looking for the compromise between price and longevity. C rating???? etc........ Should I rewire with heavier gauge wire??
Thanks in advance....
3DRCRACER is offline   Reply With Quote
Old 02-27-2010, 06:46 AM   #2
fatdaddy's Avatar
any 4 cell 14.8v lipo at least 20c discharge rate. 2500mah will work a full day with multiple cars. go as high as you want though
edit: yes, rewire it. 12ga. deans noodle is the best with some deans ultra plugs youll be set.
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 02-27-2010, 08:05 AM   #3
Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 57 (100%+)
i use 2 3500 40c lipo's.. i had them sitting around.. they came from my sedan racing. i also use 2 3400 25c lipo's and they are about the same kick from either set. the higher the mah the longer between charges.. with the ofna box i did not rewire... just changed ends to deans.. only because i had them in the pit bag... ant lipo will be better then a gel cell... jeremy
Jeremy Whiting - serpent america - desoto racing - apicco race engines - RcRenew - jconcepts - Rc Pro Products - ko propo eurus - ko propo servos - VP PowerMaster Fuels - Answer-rc usa - advantage racing products - Parma/pse bodies - serpent 811 2.1 - 811t
J.Whiting is offline   Reply With Quote
Old 02-27-2010, 10:23 AM   #4
Trader Rating: 40 (100%+)
I have the ofna blue truggy box and I just finally made the lipo switch. However I went the cheap route and ordered one of the bLue lipo 4s 2200 20c from hobbypartz.com I could t be happier! It balances well, shrink wrap was great and it turns my plus 4 over with the greatest of ease! I haven't used it in race day situation yet but for $18 and it ships from the USA and I had it in 3 days time from ordering I'm not complaining!
AndysD8 is offline   Reply With Quote
Old 02-27-2010, 03:50 PM   #5
Just got this one for my Ofna Truggy box and it makes the dual motors scream!!!!Just gotta throw your connector of choice on it and zip tie it to the box after a couple holes are drilled.
http://www3.omnimodels.com/cgi-bin/w...I=VNRP5004&P=7
Sholler is offline   Reply With Quote
Old 02-28-2010, 05:24 AM   #6
Thanks for the info guys. Really appreciate it.
Old 03-03-2010, 11:03 PM   #7
quad71's Avatar
I GOT THE OFNA TRUGGY STARTER WHIT DUAL MOTORS AND 2200 MAH 14.8V
FROM MAX AMPS WHIT DEAN,S/HYPERION PLUGS ALL SET
BUT I NEED A GOOD SHEP CHARGER/BALANCE NOW
WHAT DO YOU GUYS RECOMEND???
quad71 is offline   Reply With Quote
Old 03-04-2010, 06:38 AM   #8
Frank L's Avatar
Trader Rating: 148 (100%+)
+1 on a 4s 14.8v 20c 2200mah. I use one of those in my box and it starts several cars on race day. I have been using it in my ofna box for almost a year with great success.
Old 03-04-2010, 06:49 AM   #9
MontanaMaxx's Avatar
+2 will be just the ticket
the gel cell is 12 volt and the lipo is 14.8 thats better than 2 1/2 volts more and more volts equal less amps so not as much battery is required
MontanaMaxx is offline   Reply With Quote
Old 03-04-2010, 06:56 AM   #10
I fought with the decision to get the 20c thinking I needed more, but I can assure you more is not needed! I'd hate to see what the 30-40c lipos would do! It's just unnecessary!
Old 03-04-2010, 07:07 AM   #11
gkn0315's Avatar
Trader Rating: 126 (100%+)
To answer your question I use a maxamps 4s 25c 2200mAh lipo works great I can usually go two days of use before recharging. That is practice , 6 qualifiers, and 2 mains of use hope this helps good luck
Glenn Nail
STRC LCG Slash looking for electronics
1985 Associated RC 10 Novak t4 Trinity Monster Horsepower 27T futaba Jr
gkn0315 is offline   Reply With Quote
Old 03-04-2010, 07:24 AM   #12
Integra's Avatar
not true...the more C a pack is capable of the better.......There is such thing as Too much....but a single 4S will never peak it......2 Stick pack lipo's with high mah and C rating will tho.
Old 03-04-2010, 07:38 AM   #13
Originally Posted by Integra View Post
0
My biggest concern(and It may just be me) but even the 20c puts off enough power to where if the washer doesn't hit the contacts perfectly when you press down on the box that it's arcing off so much that it's melting the plastic around the contact that is on the switch side. I hope the way I'm explaining it makes sense. Have you ran across this issue? If so have you found a fix for it?
Old 03-04-2010, 08:13 AM   #14
losiracer78's Avatar
This is the Batt that i have been that been running my starter box for the last 16 month with out a prob. http://www.amainhobbies.com/product_...Ah-Starter-Box
Screen Names Has Changed To mayhem04
losiracer78 is offline   Reply With Quote
Old 03-04-2010, 09:10 AM   #15
Integra's Avatar
boxes melted back in the day with gel cells and Nicads and nimhs....lipo's are no different.
there are some guys who are installing relay's instead of relying on the little tabs to make the contact but imo its overkill and not needed.
Starter box Lipo rewire help. HiVoltg12 Nitro Off-Road 40 03-03-2010 09:37 AM
starter box lipo info Marcus Falconie Nitro Off-Road 20 12-09-2009 12:24 PM
Starter Box Lipo jonski Nitro Off-Road 18 11-18-2009 05:41 PM
Starter Box Lipo Conversion bigterp77 Nitro Off-Road 15 03-08-2009 08:49 AM
Starter Box Lipo Pull_My_Finger Nitro Off-Road 47 07-12-2008 05:11 PM
