Old 03-15-2010, 08:43 PM   #31
madweazl's Avatar
Originally Posted by losi_racer View Post
integra would be the one to explain it.
Why would there be an issue? In series, he'd have a 2600mah 14.8v setup that would work just fine.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 03-15-2010, 08:48 PM   #32
Originally Posted by Integra View Post
not true...the more C a pack is capable of the better.......There is such thing as Too much....but a single 4S will never peak it......2 Stick pack lipo's with high mah and C rating will tho.
Looks like maybe too much as I always get real good info from Integra. How does one figure out the power of 2 lipos running together? Add the mah and volts together? I know it cant be simple as that but you know what i mean.
Ah i see how to figure it. thanks madweazl. Still wondering why it would be an issue.
barrydidntknow is offline   Reply With Quote
Old 03-16-2010, 07:32 AM   #33
Integra's Avatar
15C is fine...its when the Onroad race's toss in a pair of 40C-50C 3600's that the motor's start to take a walk to the other side.
Old 03-16-2010, 07:47 AM   #34
If you put the packs in parallel you will add the amp ratings and the voltage will remain the same, conversely, if wired in series the voltages will add and amperage will remain at the rating of one pack. The available watts will be higher in either situation though. I see no issue at all with it as long as you use them in series to keep the voltage up. Higher voltage will result in a higher motor speed, if you ran in parallel to get the higher amperage you'd have some slow turning motors and also the motors would get hotter.
Wrencher is offline   Reply With Quote
Starter box Lipo rewire help. HiVoltg12 Nitro Off-Road 40 03-03-2010 09:37 AM
starter box lipo info Marcus Falconie Nitro Off-Road 20 12-09-2009 12:24 PM
Starter Box Lipo jonski Nitro Off-Road 18 11-18-2009 05:41 PM
Starter Box Lipo Conversion bigterp77 Nitro Off-Road 15 03-08-2009 08:49 AM
Starter Box Lipo Pull_My_Finger Nitro Off-Road 47 07-12-2008 05:11 PM
