Old 02-26-2010, 08:01 PM   #1
Default charging muchmore glow starter
hi guys,
i've got a muchmore 4500mAh glow starter. when you put a glow plug in it glows for about 1-2 secs then dies. these are three new OS P3 plugs just taken out of packet and never used so thought could be glow starter. I have a swallow charger and glow starter adaptor but tried charging at 2, 3, 4A without luck but sure it's not fully charged. any advice to charging this glow starter?
thanks.
bew79 is offline   Reply With Quote
Old 02-26-2010, 09:53 PM   #2
Trader Rating: 21 (100%+)
is the battery completely charged? if it is then probably its a bad batt, connections are fine or it wouldn't even light the plug at all
TopGearRC is offline   Reply With Quote
Old 02-26-2010, 09:58 PM   #3
2tap's Avatar
Is this a NiMH battery? Are you charging it as a Nicad?
2tap is offline   Reply With Quote
Old 02-26-2010, 10:08 PM   #4
mudboger07's Avatar
Originally Posted by bew79 View Post
hi guys,
thanks.
If its the type were you can replace the battery take it apart and clean the terminals. I had to do that with one that i bought and it now works great...
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 02-26-2010, 10:16 PM   #5
sickboy's Avatar
Trader Rating: 72 (100%+)
I have the same ignitor and ran into the same issue. Make sure to turn the amps down to higher than 1.2, make sure its set to nimh and make sure your polarity is correct on your charge lead. Ihis ignitor likes to be charged at a low amperage.
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 02-27-2010, 02:35 AM   #6
thanks for the advice, will try charging at a low amp rate, everything else on charger OK.
if i insert a glow plug it glows for a couple of secs and goes out. take out an insert again and will glow again but for less time, and each time less and less glow for about 5 goes which got me thinking it was the battery. will let you know how I get on. i'm trying to run in my new Alpha Z852 so need it to stay on for a while whilst it turns over and tries to fire for the first time.
how to DIY Glow Starter Charger Connector uniquexme Nitro On-Road 6 06-25-2006 05:43 PM
