Old 02-26-2010, 06:33 AM   #1
mista.matrix's Avatar
Default Jammin x2 set-up sheet
Anyone know where I can jammin x2 CRT set-up sheet info, I looked at jammin's website the newest one is from a year ago, any have any ideas....?
mista.matrix is offline   Reply With Quote
Old 02-26-2010, 09:49 AM   #2
mblgjr's Avatar
Trader Rating: 86 (100%+)
This truck has it's own thread with setup tips in there btw; take a look when you get a chance.
Otherwise, the Chad Bradley std. setup sheet is a fine starting point overall.
Chad's standard; dated 6/08
http://www.jamminproducts.com/setups.htm
Drop the center diff to 15k for *most* people; most also prefer to run 3deg. of rear toe in.
Otherwise on a full weight truck all the pick up points and shocks stay the same.
If you want to get creative you can run some 9mm offset hubs (Kyosho) and swap to 0-offset wheels and blue rear springs. This narrows the truck a bit and makes it more responsive; a lot of the team guys have been running this for a while. Makes the truck a lot better on tight tracks.
Also check this thread for some interesting info:
http://www.neobuggy.net/modules/newb...=ASC&start=910
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Jammin X2-CR ?? (buggy?) orzel24 Nitro Off-Road 441 05-13-2015 06:34 AM
JAMMIN X2 CRT!!!! luis carballo Nitro Off-Road 1009 02-07-2015 02:53 PM
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 01:07 AM
Jammin' X2 Buggy NsideLine Nitro Off-Road 479 09-02-2010 10:36 AM
