Old 02-25-2010, 04:28 PM   #1
losi_racer's Avatar
Trader Rating: 25 (100%+)
Default Radio tray cleaning question
ok guys, as you might know at the nitro challenge it god muddy. my radio tray got missed somehow and its pretty dirty, its not bad but its more dirty then usual. anyway my question what is a safe and efficient way to clean it WITH the electronics in there?
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 02-25-2010, 04:30 PM   #2
Black's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to Black
I take my radio tray out and the put a FINE mist of simple green/water on the entire thing and scrub it real well then spray off with an air compressor. I
JConcepts/Werks Racing Engines/Ironman Bearings/PowerMaster Fuel/VP Racing
Black is offline   Reply With Quote
Old 02-25-2010, 05:03 PM   #3
sickboy's Avatar
Trader Rating: 72 (100%+)
wd40 and a tooth brush
Tamiya America www.tamiyausa.com
Team TRF www.teamtrf.com
Pro-Line www.prolineracing.com
818Designs.net - TKO
sickboy is offline   Reply With Quote
Old 02-25-2010, 05:08 PM   #4
madweazl's Avatar
WD40 is a dust magnet. I just use a wet rag and a tooth brush for the nooks and crannies. My stuff is always spotless.
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 02-25-2010, 05:09 PM   #5
Trader Rating: 61 (100%+)
i use a contact cleaner like kal gaurd or nitrotec and go easy around the servos ...then take a brush and brush off the loose stuff ..then hit it with the air compressor to blow away everything else ..then i take a detail brush and spray it with a little wd40 and brush everything down really good ..then hit it with air again ..and then some prep shine if you want it to sparkle really good ....as long as you hvae the right brushes your good ...take a small paint brush and the bristles at about a 1/4 inch ..makes a good detail brush
LATER COOKIE
TEAM REDS RACING ENGINES USA
TEAM PROLINE-RACING
TEAM RC AMERICA/XRAY/HUDY
zixxer is offline   Reply With Quote
Old 02-25-2010, 05:27 PM   #6
If it's really bad I'll use denatured alcohol in a siphon sprayer. Otherwise, I just blow it off and wipe it down w/ a rag.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 02-25-2010, 05:43 PM   #7
wfo
wfo's Avatar
+1 for a final touch a spay a light coat of sc1 on my toothbrush and detail away.....
wfo is offline   Reply With Quote
Old 02-25-2010, 05:47 PM   #8
fatdaddy's Avatar
the trick to the wd40 is you have to let it sit on there for a while to let it all soak into the plastic. once its dry it repels dirt very nicely.
definitely not to be used inbetween rounds. i bet its a dirt magnet then!
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 02-25-2010, 05:59 PM   #9
Go to Dollar General and you get yourself a tube of eyeliner. Take the brush out and clean the paint off.
Get some simple green and mildly mix it with wawa. Lightly spray and brush with a toothbruss then get all the nooks and crannies with the eyeliner brush.
I've been using the eyeliner brush for a while and it works well.
Franchise is offline   Reply With Quote
Old 02-26-2010, 01:46 AM   #10
merdith6's Avatar
Default WD40
On a toothbrush....
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Hyper 9 Kits in Stock! bola Nitro Off-Road 2373 01-02-2013 03:43 PM
DREAUX'S PERSONAL THREAD roadracer43 Nitro Off-Road 422 04-15-2011 06:38 AM
I am Torn... Euro Stealth Nitro Off-Road 55 11-04-2008 03:53 PM
