Old 02-21-2010, 05:58 PM   #1
Default I made a big mistake! (your gonna love this)
So i am breaking down my engine. I was impatient at the moment with my wife yelling at me to go to the store. well i am trying to get the flywheel off and i am taping and taping the back of it (like i always do to get it off), and it wouldn't come off. Meanwhile my wife is nagging and nagging. So i said screw it and to out my 4oz ball ping hammer and started tapping on the end of my crank shaft.
It finally came off. So later i am putting it back together and the flywheel will not go on, and i couldn't figure out why. Well the tip of the crank mushroomed a itty bit. So i filed the end a little and it went back on. If the crank bent any i could not tell. It was smooth with the bearings and when i run it the clutch and spur are fine.
So basically from what i can tell everything is fine. But would like you guys input on this. Did i ruin my crank?
This is embarrassing
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 02-21-2010, 06:08 PM   #2
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
hmmm how hard did you hit the crank on the end when the flywheel did come free is my concern... would do more damage putting that stress on the crank pin and con rod ( and piston sitting in the sleeve ) than on the end up the crank itself, if you only burred the end up and now everything goes on ok it should be ok but i would be concerned about damaging the internals of the engine more....
NJA82 is offline   Reply With Quote
Old 02-21-2010, 06:14 PM   #3
I took the P/S and rod out. SO it was just the crank i was taping on.
I do some dumb stuff, but not that dumb
Mugen
Old 02-21-2010, 07:52 PM   #4
BIG RE's Avatar
Trader Rating: 32 (100%+)
sounds like someone needs to invest in a flywheel puller
BIG RE is offline   Reply With Quote
Old 02-21-2010, 07:56 PM   #5
+1 You took the words right out of my mouth.....or...keyboard
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 02-21-2010, 08:10 PM   #6
pep boys or kragen,what ever you have out there sell windshield wiper pullers for $8. Stop by on your way home,just use a bolt in the end of the crank when using it or rigging like you just did(stops the mushrooming).
"TEAM TERRIBLES"
butch man is offline   Reply With Quote
Old 02-22-2010, 12:16 AM   #7
mblgjr's Avatar
Trader Rating: 86 (100%+)
Heat the flywheel with a heat gun next time.
Get it nice and hot.
As the aluminum (or steel) flywheel cools; there will be a release point where it will just 'let go' from the collet real easily without having to beat it into oblivion.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 02-22-2010, 04:18 AM   #8
triplesix's Avatar
Conclusion:
In the end, it's all the wife's fault, right?!
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 02-22-2010, 04:32 AM   #9
RX313BT's Avatar
Trader Rating: 14 (100%+)
I if it all went back together ok, then i would just run it and see how it goes, but yes get a flywheel puller.
Adelaide RC Team Driver
WWW.ADELAIDERC.COM.AU
Xray XB9 & XT8.5, Proline, Nitro-X Fuel.
Xray XB4, Nosram, Proline.
TLR22,TLR22T Model Flight.
RX313BT is offline   Reply With Quote
Old 02-22-2010, 05:44 AM   #10
JQ
Thats nothing. I know someone who couldnt get the flywheel off. He was using a flywheel puller too. When in doubt, use brute force, so he did and it did come off. Unfortunately so did the crank, since he had forgotten to actually take the flywheel nut off ! :-D
And no it wasnt me!
JQ is offline   Reply With Quote
Old 02-22-2010, 06:32 AM   #11
Madbrad's Avatar
Trader Rating: 29 (100%+)
And no it wasnt me!
LOL, that goes to show you it can always be worse !
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 02-22-2010, 09:31 AM   #12
Originally Posted by triplesix View Post
Conclusion:
This wifey thing always there to ruin whatever you doin with this hobby.
whiterice is offline   Reply With Quote
Old 02-22-2010, 04:03 PM   #13
And no it wasnt me!
HA HA HAHAHAHAHAHA!!!! Man that is pure gold!!!!
Man if you only had it on video
Mugen
Old 02-22-2010, 04:10 PM   #14
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
+1
I remember the days(long time ago) when I was naive and used to tap the crank just like that to get the flywheel off when it was really stuck. I mushroomed a couple cranks myself(RTR engines though) and had to get filing. It should be fine as long as everything goes on and off smoothly, but I would HIGHLY recommend a flywheel puller for the future.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 02-22-2010, 04:22 PM   #15
Trader Rating: 47 (100%+)
So your saying that your wife is like dreaux's wife and has
you beating your own crank too?
rageworks is offline   Reply With Quote
