Old 02-20-2010, 11:43 AM   #1
trickedout's Avatar
Trader Rating: 31 (100%+)
Default Different p/s/r in motors.."swapping parts"
Hey just wondering if you have a motor with bad rod or piston and sleeve or what have you...if you find a new rod from a different motor but its specs are the same is there a reason it wouldnt work?? i understand if you found a longer rod that it wouldnt work but if they were the same length or whatever can you swap parts..mainly due to the fact that some motors replacment parts are way more expensive then others???
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 02-20-2010, 03:45 PM   #2
8&stuff's Avatar
Trader Rating: 55 (100%+)
I know people that yeild great results with swapinstien engines. I also know guys that have quit the hobby swapping internals because it never worked out for them. No matter what, when switching rods a break in procedure should be done. If your measurmants are correct and look to be same hopefully break in will go ok and things will work out fine. Myself i would only consider using same brand replacement internals. I have tried different rods in engines a couple times and either measurmant were off barely or way too much once i tried to assemble..
Mark Buecker
8&stuff is offline   Reply With Quote
Old 02-20-2010, 04:19 PM   #3
j_blaze14's Avatar
Trader Rating: 34 (100%+)
mutt motor, i believe that is how the fms was born, on road and off road parts together. i mutted sts and go motors before with ok results. give it a shot, if it does not run stop to save what you can.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 02-20-2010, 08:30 PM   #4
trickedout's Avatar
thanks for the replys ill give it a shot as its not my race motor anymore and have nothing to lose thanks guys!
Old 02-21-2010, 12:04 AM   #5
triplesix's Avatar
go engines are roughly based on novarossi dimensions. i've heard a few times, people were trying gen5 go rods in nova/rb engines without problems. price difference is huge. i myself put an rb carb on my go 217pt 'cause i found it easier to tune.
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
