Old 02-20-2010, 10:36 AM   #1
slasher man's Avatar
Default turbo plugs good or bad
are turbo plugs good for ur engine or bad wats the diffrence of the regular and turbo
sh zmxb-8 odonel zo1b
slasher man is offline   Reply With Quote
Old 02-20-2010, 11:18 AM   #2
Roelof's Avatar
Send a message via ICQ to Roelof
With plugs the glowwire is the most important part to run your engine. The turboplug has a better sealing wich will give more compression giving a slightly more power.
One bad thing of the turboplug is the missing copper ring, those rings are very usefull to shim 6mm axles in your car
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 02-20-2010, 01:18 PM   #3
mudboger07's Avatar
You also want to make sure your motor has a head button made for a turbo plug, if not they will not work correctly...
Proud Sponsor of a 10 year old.....
losi 8ightB 2.0/DX3S/VSpec* Revo-3.3*mod slash*blade-mcx*axial GC2
Team Nitro** F-14*Team Terribles/Answer-RC
Ken
mudboger07 is offline   Reply With Quote
Old 02-20-2010, 05:38 PM   #4
coviello's Avatar
turbo and regular are two different kind of motors.
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 02-20-2010, 06:06 PM   #5
mudboger07's Avatar
sorry bought that but that answer is wrong, You can take a motor that has a button head and replace it with a turbo head button and it wil work fine...or the other way around.....
Ken
Old 02-20-2010, 07:25 PM   #6
jonski's Avatar
Trader Rating: 233 (99%+)
That's correct...Losi just released a conversion for the 454 motor in their RTR's.
jonski is offline   Reply With Quote
Old 02-20-2010, 11:01 PM   #7
mblgjr's Avatar
Trader Rating: 86 (100%+)
Since we're already off to a slightly misinformed and rocky start...
Here you can see the illustrated difference between a turbo (on left) and standard (right).
Turbo has a tapered seat and uses no washer. Thus, the head button must be able to accept it, so make sure you have a turbo head button first as the plug types are not interchangeable.
As Roelof said, they make a bit more power, generally pull slightly smoother and can get a *touch* better fuel mileage.
They're not "bad" in any way; but can be faintly less forgiving to tune. Neither plug design is "good or bad" for your engine. By design they both function the same; the turbo is just a little better at it
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Burning glow plugs?? tylerp_2000 Monster Trucks 21 05-14-2009 05:50 PM
