Old 02-19-2010, 08:36 PM   #1
slasher man's Avatar
Default tire questions
how can i make my tires last longer and wat are the longest lasting tires on the market
sh zmxb-8 odonel zo1b
slasher man is offline   Reply With Quote
Old 02-19-2010, 08:46 PM   #2
Trader Rating: 12 (93%+)
what kind of stuff you doing, racing or bashing? The harder the tire compound the longer it will last. For bashing the longest lasting tire would be the the badlands. Good luck
rcdude236 is offline   Reply With Quote
Old 02-19-2010, 09:05 PM   #3
shanty140's Avatar
The harder the compound the longer the tire will last. But in trade you will lose tire traction as softer tires give you more grip.
Looking at your picture I would assume you are talking buggy tires. If you are bashing I would recommend either Proline Badlands or Proline Knuckles. They have larger lugs so it makes them last much longer. If you are bashing and will run on the street. Stay away from small pin tires as they will wear away in minutes.
If you are racing and would like longer lasting tires I would recommend the Proline Caliber, Jconcepts Subcultures, AKA I-Beams, AKA Crossbrace, Proline Crimfighters, Jconcepts Double Cross, and Jconcepts Crossbows. These are off the top of my head so I may be missing some. When looking for long laster tires, look for ones that have a larger pin style and not small like AKA Gridirons. Also, AKA has a new tire coming out called the ENDURO. It's looks that it could be a tire that has good traction, but super long lasting.
Also one thing to remember when running buggy is they can be VERY hard on tires if you are not smooth with the throttle. So the first thing to learn when looking to make tires last longer is be smooth on the throttle. This would also help run times as well.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
Old 02-20-2010, 04:45 PM   #4
crookdaddy's Avatar
Trader Rating: 23 (96%+)
HOW CAN YOU PUT A HOLE IN THE TIRE WITH OUT A LEATHER PUNCHER
crookdaddy is offline   Reply With Quote
Old 02-20-2010, 05:08 PM   #5
jjshbetz11's Avatar
surgical scissors, I cut a SMALL diamond shape.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 02-20-2010, 05:14 PM   #6
Trader Rating: 46 (98%+)
i use a dremel or drill. you just need to clean up the hole when you are done.
consistency will get you better results than speed, but if you have both-look out!!
Agama A215T
thanks to Tony Bacon, Dialed-rc hobbies, Nemoracingusa.com
nitroal is offline   Reply With Quote
Old 02-20-2010, 05:18 PM   #7
crookdaddy's Avatar
I HAVE A HOLE PUNCHER OR REAMER HOW MANY HOLES 4 IN EACH CORNERS
Old 02-20-2010, 05:19 PM   #8
jjshbetz11's Avatar
2 per tire vertical from each other
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 02-20-2010, 05:21 PM   #9
crookdaddy's Avatar
DO U NEED 4 HOLES SMALL OR 2 BIGGER SIZE
Old 02-20-2010, 05:23 PM   #10
crookdaddy's Avatar
HOW ABOUT A REAMER THEN RAZOR BLADE 2 CLEAN IT UP
Old 02-20-2010, 05:24 PM   #11
jjshbetz11's Avatar
sounds good, would be carefull though, dont take much to slice them
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 02-20-2010, 05:25 PM   #12
crookdaddy's Avatar
HERES ONE ANY TRICKS ON GETTING A TIRE OFF THE RIM AFTER ITS CUT OFF
Old 02-20-2010, 05:27 PM   #13
crookdaddy's Avatar
THX DON'T WANT 2 SCREW UP MY TIRES
Old 02-20-2010, 05:27 PM   #14
jjshbetz11's Avatar
I like the baking technique, 350 on oven, turn oven off, put tires on foil, set timer for 15 min. Should come off easily, repeat if needed.
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
Old 02-20-2010, 05:31 PM   #15
crookdaddy's Avatar
DUH I TOTALLY 4GOT THX U DA MAN
Foam tire questions for RC18T... MojoManDan Micro and Mini Scales 13 03-24-2009 12:31 PM
Foam Tire Questions SlamMan Nitro On-Road 39 05-04-2007 03:54 PM
CS 27 and general rubber tire questions J.Gonzalez Electric On-Road 16 06-12-2003 11:28 AM
