Old 02-20-2010, 05:33 PM   #16
Originally Posted by crookdaddy View Post
HERES ONE ANY TRICKS ON GETTING A TIRE OFF THE RIM AFTER ITS CUT OFF
I soak them in acetone. I just put about 1/2" of acetone in flat baking pan, put in the tires and cover w/ foil to keep it from evaporating. Let it soak about 5-6 hours and the tire bead comes right off. Flip and repeat. Always has worked for me.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 02-20-2010, 06:31 PM   #17
thrash_16's Avatar
why do you need o put holes in the tires???
thrash_16 is offline   Reply With Quote
Old 02-20-2010, 06:49 PM   #18
shady3031's Avatar
Trader Rating: 26 (100%+)
The holes are there to let air out. When you jump and land if there are no holes in the tires it will cause the vehicle to feel spongy, and the suspension will not work properly
2 holes in the center of the tread 180 degrees apart-leather punch works great
The Warehouse RC-Birmingham, AL
AE RC8.2-E Tekin powered
Alabama Manufacturers Shootout-Don't Miss It
shady3031 is offline   Reply With Quote
Foam tire questions for RC18T... MojoManDan Micro and Mini Scales 13 03-24-2009 12:31 PM
Foam Tire Questions SlamMan Nitro On-Road 39 05-04-2007 03:54 PM
CS 27 and general rubber tire questions J.Gonzalez Electric On-Road 16 06-12-2003 11:28 AM
