Old 02-19-2010, 06:19 PM   #1
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
Default What is the best way to pull a bearing?
May have to pull a bearing from a motor and was curious to how to do it without having to pay out the 60 bucks for a bearing puller?
kodiakbear7070 is offline   Reply With Quote
Old 02-19-2010, 06:26 PM   #2
Trader Rating: 18 (100%+)
The best way to get bearings out of an engine is to heat it up in the oven and then the bearings fall out.be sure to take the carb off.
David Osborne,
Nemoracing usa
Gofast hobbies,West Virginia hobbies
Amain Hobbies
Fioroni usa
xxxntwv is offline   Reply With Quote
Old 02-19-2010, 06:59 PM   #3
8&stuff's Avatar
Trader Rating: 55 (100%+)
If you race ask a local with a bearing puller. The oven method works although sometimes need a wooden dowel to give it that extra umph
8&stuff is offline   Reply With Quote
Old 02-20-2010, 12:01 AM   #4
MontanaMaxx's Avatar
i like to use the propane torch it applies the heat much faster and the bearings dont expand as fast so they come out easier
MontanaMaxx is offline   Reply With Quote
Old 02-20-2010, 07:24 AM   #5
Kalgard Racing's Avatar
I have a Milwaukee Heat gun and it heats the motor up in a vise to well over 250 and quick, grab the motor with a welding glove, tap on a piece of wood and they fall right out.
Kalgard Racing is offline   Reply With Quote
Old 02-20-2010, 08:03 AM   #6
ALG
+1
ALG is offline   Reply With Quote
Old 02-20-2010, 08:34 AM   #7
wfo
wfo's Avatar
I use my wifes little toaster r oven set at 275 for about 8 min .. use an oven mit to grab it and have a 4x4 piece of wood to smack it on (back plate side) if it doesnt fall out turn the heat up a little some motors are tighter then others...
wfo is offline   Reply With Quote
Old 02-20-2010, 11:40 AM   #8
trickedout's Avatar
Trader Rating: 31 (100%+)
hey ive never pulled bearings before but i need to on a jpx.21..just to be clear the rear bearing comes out through the backplate?? is this the same way to remove the front bearing only out the front i would asume?
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 02-20-2010, 12:43 PM   #9
Heat gun and a wooden dowel for me...Just make sure to not use anything metal...You can't get yourself into trouble with a dowel.
HiVoltg12 is offline   Reply With Quote
Old 02-20-2010, 02:52 PM   #10
When you put the new bearing in, heat up the engine and put the bearing in the freezer for about 10 min. then press the new bearing in. My brother uses a socket that just hits the outer race of the bearing to tap in in. Don't put any pressure on the inner race, could cause damage to the bearing.
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 02-20-2010, 03:15 PM   #11
Roelof's Avatar
Send a message via ICQ to Roelof
Be sure to place the bearing(s) in the right way.
For the rear bearing it is better to put it first on the crankshaft and drop in the shaft with the bearing. It takes out the possibillity the bearing goes wrong.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
clutch bearing problems cwalters Electric Off-Road 39 09-11-2006 06:59 AM
Who makes the best Ceramic bearings, money is not an option dawgmeat Electric On-Road 70 02-01-2005 12:17 PM
