Old 02-17-2010, 04:50 PM   #1
mazdamike's Avatar
Send a message via AIM to mazdamike
Default Can i put a JPX .28 in my RC8?
I got the RC8 RTR about a month ago, and realized the pro .28 just isnt doing it. would i have any problems if i was to put the jammin .28 in it?
HPI Baja 5B-SSWC
FG marder
mikesgs430tt@aol.com email
mazdamike is offline   Reply With Quote
Old 02-17-2010, 05:05 PM   #2
jmaxey51's Avatar
you can put it in there just fine but that is way too much power for racing. a jammin JPX 21 is plenty fast for a truggy. but if bashing the 28 will be fine, it will have more power than you can ever use. a stock jammin 21 is extremely fast and if high bite track you will hit the wing pretty easy. either one youll have one of the fastest engines out there, stock engine that is. also look at the ofna JL 21 extremely good engine and its only 175.
jmaxey51 is offline   Reply With Quote
Old 02-17-2010, 05:29 PM   #3
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
yes i agree. i would get the jammin jpx.21 over the .28 they have way to much power and the .21 in plenty! i have one and love it!
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 02-17-2010, 06:17 PM   #4
rider313's Avatar
Trader Rating: 94 (100%+)
keep the pro .28 and you could spend about $50 and have it modded. If your just going for fun. If you plan to race i would recomend a .21, since any larger is illegal.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 02-17-2010, 06:23 PM   #5
Thunder tiger makes a .90
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 02-17-2010, 06:27 PM   #6
Dylan Gerard
Old 02-17-2010, 06:28 PM   #7
rider313's Avatar
isnt that a twin? JW
Dan Williams
MNRC Chairman
Old 02-17-2010, 06:33 PM   #8
+1
nothin special is offline   Reply With Quote
Old 02-17-2010, 06:37 PM   #9
Trader Rating: 36 (100%+)
IMO, before you consider modding...try a top end oriented pipeset. Ofna or Dynamite 086 or Jammin JP series...I think the 3 is the top end version. Consider changing your clutch set up too. Or at the very least, take the bell off and clean things up. If you're going to buy a new mill, I agree with the general consensus, .21 over a .28.
1) If you're going to race, technically .28s are illegal for buggies (I'm assuming you have a buggy, not a truggy?) Granted, your local track may let you slide, but if you race any sanctioned events, they likely won't let you run a .28 in a buggy. If you're only bashing and are merely out for all out brute power, then enjoy the .28...but keep in mind, being a larger mill, it also has a larger appetite.
2) Another thing to consider is that you'll likely need to also get a starter box, I don't believe any of the Jammin mills are available as a pull start, and I'm guessing your current mill is.
NitroOB4You is offline   Reply With Quote
Old 02-18-2010, 05:23 PM   #10
mazdamike's Avatar
yea it has the pro start on it. i just added the JP2 pipe and a 17t pinion. be dying to run it .except we been getting snow like every week here.could i mess it up by running it in a little snow?
HPI Baja 5B-SSWC
FG marder
Old 02-18-2010, 05:31 PM   #11
Running in the snow is not a good idea. Water will go into electronics and will make metal parts and screws rust.
For the engine, if you don't race, keep the stock .28 and add aluminum clutch shoes and 1.0mm clutch springs. This will increase acceleration. Also, make sure your engine is correctly tuned.
If you absolutely want to replace the engine, buy a new one (and a tuned pipe) and keep the .28 as spare.
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 02-18-2010, 06:44 PM   #12
rider313's Avatar
Ya its not worth it in the snow. Have you got a set of ALM clutch shoes yet. That will make a big differnce to.
Dan Williams
MNRC Chairman
Old 04-07-2010, 05:24 PM   #13
mazdamike's Avatar
yea im just bashing around with my friends . im basicly looking for somthing faster than the werks B7 and faster than the jl .21
do u guys think the jpx .28 is faster?
HPI Baja 5B-SSWC
FG marder
Old 04-07-2010, 05:43 PM   #14
jmaxey51's Avatar
a JPX 21 will be faster than those... a 28 will blow your diffs....
Old 04-07-2010, 05:48 PM   #15
MadRussian's Avatar
+1
MadRussian is offline   Reply With Quote
Tags
jammin .28, rc8
