Old 02-16-2010, 07:59 AM   #1
Default my 7075 restyling CHASIS... Part I
Diego.
Thanks.
my 7075 restyling CHASIS... Part I-hyper_8.5_evo_05.jpg   my 7075 restyling CHASIS... Part I-kyosho_kanai_evo_00.jpg   my 7075 restyling CHASIS... Part I-kyosho_kanai_evo_01.jpg   my 7075 restyling CHASIS... Part I-hyper_8.5_evo_04.jpg   my 7075 restyling CHASIS... Part I-x_ray_808_00.jpg
Dieguito is offline   Reply With Quote
Old 02-16-2010, 08:45 AM   #2
Originally Posted by Dieguito View Post
Diego.
Thanks.
Looks strong but looks heavy. Neat though.
Franchise is offline   Reply With Quote
Old 02-16-2010, 09:00 AM   #3
in fact... the weights are generally the same that the originals...
some cases.. the weights is less than the originals...
The maximun thickness is 5.2 mm..
The minimun thickness is 1 mm..
Diego.
Old 02-16-2010, 09:14 AM   #4
fatdaddy's Avatar
why does this look framiliar? i thought ive seen this before somewhere else.
its looks nice, but i would think it would be too rigid, and the lack of chassis flex would hurt handleing. also i could imagine that chassis filling up with dirt or mud pretty easily. and with everything mounting up so high on the chassis i would think the COG would really be affected negatively.
it is pretty though
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 02-16-2010, 09:18 AM   #5
Yea dirt would get in there but I don't see it being that much of a problems unless mudding. It would however catch all the fuel my pitman can't seem to get in my tank(fuel gun this season) and the screws I drop.
Old 02-16-2010, 09:23 AM   #6
sorry... wath is COG?!!!!....
as in the real sports cars... the chasis must be all that rigid is posible... to ensure that the suspension elements.. works as be thinked...
If the chasis fly as a flowing carpet... itīs NOT GOOD!!!!!....
The chasis.. is the chasis...
The spring is the spring..
the shock absorver.. is the shock absorver... etc...
All suspension elements must be suported by the chasis...
The chasis must work like a structure.. NOT like a suspension element...
This is the universal chasis Theory...
Diego.
Old 02-16-2010, 09:32 AM   #7
jjshbetz11's Avatar
well these chassis do need flex, it's preety though
Losi 8ight 2.0 RR
Werks Racing
Hi-tec
Spektrum
jjshbetz11 is offline   Reply With Quote
Old 02-16-2010, 09:32 AM   #8
slaytanic's Avatar
Trader Rating: 20 (95%+)
Those are blingy! Not true on chassis flex though. It is a viable tuning option and is used across rc classes. Look at durangos new buggy. Tuned Chassis flex. Nice looking pieces though. Thats a hunk o metal there!
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 02-16-2010, 09:33 AM   #9
fatdaddy's Avatar
Diego.
COG = Center of Gravity
i hate to break it to you, but our chassis work nothing like they do on real sports cars.
good luck!
Old 02-16-2010, 09:54 AM   #10
rider313's Avatar
Trader Rating: 94 (100%+)
even in motocross we deal with chassis flex. If the frame isto rigid the bike handles like crap, so most manufactures feed more flex into it for the next year. Offroad vehicles like a flexy chassis to work off. I i heard some onroad guys say the same thing.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 02-16-2010, 09:57 AM   #11
please tell me...
If you think that the chasis must be flex...
Can you explain this??!!!!....
The 1/8 nitro Off Road do all that do real 1/1 sports cars..
If the 1/8 Nitro Off Road have to avsorb the track imperfections...
the elements for that mission are springs, tires, inserts, shock obsorvers and antirroll bars...
Wath you think.. tell me!!!
Diego.
Old 02-16-2010, 10:01 AM   #12
Center Gravity itīsnt a part of the suspension....
COG nothing have to do with the suspension...
The COG.. may be affect litlle when the car is flyng.. nothing more...
Diego.
Old 02-16-2010, 10:07 AM   #13
mblgjr's Avatar
Trader Rating: 86 (100%+)
We've had it out with the OP here before about the flex; so let him go try his stuff and see what he things
IF (big IF we had better shocks...then yea I could see stiffening the frame. But until then; the tires, wheels, stiffness of the plastics...ALL are part of the 'suspension' spring/feel.
Can you go too far with the flex? Yes.
Can you go too far with the stiffness? Yes.
Do most real cars strive to achieve maximum stiffness on a given platform? Yes...BUT...they typically fail within certain design limitations, so it still flexes
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 02-16-2010, 10:10 AM   #14
mblgjr's Avatar
Diego.
Center of Gravity has a direct correlation to HOW the suspension works/reacts and the vehicle drives
Because everything mounts on top of the chassis for RC; if you maintain your suspension angles (i.e. dogbones level at ride height); with your thicker frame, you'll lose ground clearance (based on it being 5mm nominal thickness; vs. normal 4mm frame). The added weight down low should actually lower your CG a bit.
For those interested; this is a good *basic* article regarding CG and how some things can affect it. (Not RC; but can relate)
http://firechief.com/apparatus/vehicle_cog_0907/
Old 02-16-2010, 10:12 AM   #15
Stubbs's Avatar
Trader Rating: 57 (100%+)
Diego.
The CG will most certainly affect the handling of the car on the ground, not just in the air. A higher CG will cause the truck to dive forward more on braking, squat more on acceleration, and roll more in turns. This is all due to the higher bending moment imparted on the suspension components by having the CG higher up on the chassis.
Regarding flex, Losi, among others uses TFT (Tuned Flex Technology) to incorporate specific flex points along the chassis. A rigid chassis relies solely on the suspension to dampen all shock. A flexible chassis allows some of the more rigid impacts to be distributed over a larger area.
I'll leave you with a little bit of Zen Philosophy that applies to this discussion...."That which does not bend...breaks".
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
