Old 02-14-2010, 03:23 PM   #1
alexrckid's Avatar
Default lean low end causing overheating..??
on a race engine, COULD running the low speed adjustment even just a pinch too lean cause the engine to run hot..??
2008/2009 northeast super series Production MT champion
8T-2.0, werks B5, 2013, hitec's.
gallimods hobbies and raceway, barn/wolcott.
living in north myrtle beach. race at badlands
alexrckid is offline   Reply With Quote
Old 02-14-2010, 03:52 PM   #2
Gixxer2k4's Avatar
Send a message via AIM to Gixxer2k4
A lean bottom end can cause it to run hot.
Mini 8ight
Gixxer2k4 is offline   Reply With Quote
Old 02-14-2010, 04:09 PM   #3
but a lean bottom is better then a lean top
"You are not understanding the fundamental principles of my fragmented personality"
Mugen
dreaux is offline   Reply With Quote
Old 02-14-2010, 04:11 PM   #4
alexrckid's Avatar
this overheating problem seems to happen after racing for a few minutes...
Old 02-14-2010, 04:35 PM   #5
DPowers's Avatar
Trader Rating: 79 (100%+)
have you tried to richen it up when it starts running hot? if so it could be a couple of things clutch dragging air leak you could start out richen the top about 1 full turn and drive it till it gets up to temp if it still over heats when you richen the top i would say check for air leaks.
DPowers is offline   Reply With Quote
Old 02-14-2010, 04:55 PM   #6
j_blaze14's Avatar
Trader Rating: 34 (100%+)
lsn has the biggest effect on engine temps. pinch test never fails, clear out the motor on the box, after the motor drops to idle pinch the fuel line right before the carb with some needle nose and count to 4. if its still running when you hit 4 you are on the rich side, if it is dies before you hit 4 your on the lean side. if it dies right when you hit 4 you are dead on race tune, adjust the idle stop screw so the engine drops to idle about 10 seconds after clearing it out.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 02-14-2010, 08:51 PM   #7
jbright33's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to jbright33
do the shake test... clear the car out shake it if it winds it lean if you hit the gas afterwords and it bogs it rich. just learned this one from edd bridges(ebmods) when he was helping me last race. think thats the right directions lol
JESSE BRIGHT
jbright33 is offline   Reply With Quote
Old 02-14-2010, 09:08 PM   #8
Racecrafter's Avatar
Trader Rating: 25 (96%+)
No No NO.....
Shake some dried chicken bones in your hands and roll them out on pit lane.
If they spell "DEATH" you are too lean.
If they spell "MONEY" you are too rich.
If they spell "SUCCESS" then your tune is right on.
Jimmy Wright
www.trackstarrc.com ~ www.facebook.com/TrackStarRC ~ Home of the 2x's Stock Nationals Champion TS-Gold & TS-Black tire sauce, TS-1+ lubricants, TS-Precision bearings, XRG Xtreme Racing Grease, Scale Auto Engineering, ElevenTech, WRD2, Carbon 12, Stiff Products
Racecrafter is offline   Reply With Quote
Old 02-15-2010, 03:36 AM   #9
Originally Posted by Racecrafter View Post
No No NO.....
I just KNEW that has the right way.
The Working Man is offline   Reply With Quote
Old 02-15-2010, 09:28 AM   #10
rider313's Avatar
Trader Rating: 94 (100%+)
an overly rich low end can cause overheating to. say what??? think about it. you have a rich low end and dont know it. so while tuning you exibit a bog at mid rpm, so you lean the top end to get rid of it. An overly rich bottom end can cause a tuner to make and overly lean top end. which would cause overheating.
Dan Williams
MNRC Chairman
---Xray, RC America, Pro-Line Racing, FX Royal, Hudy, KO Propo, 92zero Designs, Vision Racing Products, RW-Mods, Team Loosenuts, forddesigns.net--- Big Thanks to: Wheel Brokers Track and Shop, Pine City MN~ "Stompy"
rider313 is offline   Reply With Quote
Old 02-15-2010, 09:36 AM   #11
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
No No NO.....
idk i just listen to mine,, and she tells me secrets.....
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 02-15-2010, 09:43 AM   #12
Default re
on another very overlooked note a bad bearing in your drivetrain wheels diffs etc can also cause an overheat in your engine,also when you "clear"out your engine on the box it should not take 10 seconds to return to an idle
toofless is offline   Reply With Quote
Old 02-15-2010, 07:18 PM   #13
alexrckid's Avatar
thanks for the info, guys....will come in handy this coming w/e(motorama)...
Picco P7 Evo 2 brianhatesnitro Nitro Off-Road 247 02-07-2010 02:18 PM
Help with switching to 30%. rcpilot Nitro On-Road 17 06-21-2002 06:56 AM
