Old 02-15-2010, 06:10 AM   #31
blade954's Avatar
Trader Rating: 23 (100%+)
Any one have a picture or something at how they work, Or set up on the engine..
blade954 is offline   Reply With Quote
Old 02-15-2010, 06:55 AM   #32
rcfoxhound's Avatar
Trader Rating: 14 (100%+)
Default heater
hope this loads
Favorite brands whatever works.
rcfoxhound is offline   Reply With Quote
Old 02-15-2010, 06:56 AM   #33
rcfoxhound's Avatar
Default heater
Old 02-15-2010, 07:11 AM   #34
rcfoxhound's Avatar
Default try this one
Old 02-15-2010, 07:23 AM   #35
rcfoxhound's Avatar
Default heater
my pictures s__k there is a 3 ft 110v cord,and it uses alligator clip to close band onto sleeve.leave it on engine when you start,1/4 lap to clear engine and check your tune everything is heat soaked.
Old 02-15-2010, 10:30 AM   #36
PowerHouse's Avatar
Trader Rating: 66 (100%+)
Here are a few shots for those of you who wanted to see it in action
engine warmer qustions-heat-2.jpg   engine warmer qustions-heat-3.jpg   engine warmer qustions-heat-4.jpg   engine warmer qustions-heat-5.jpg   engine warmer qustions-heat-6.jpg
PowerHouse is offline   Reply With Quote
Old 02-15-2010, 10:32 AM   #37
PowerHouse's Avatar
Here is what it looks like packaged.
Old 02-15-2010, 11:05 AM   #38
Stubbs's Avatar
Trader Rating: 57 (100%+)
And as an added bonus, if it's REALLY cold outside, just grab the head on your engine while the heater's on it (with your gloves on of course)....warms the fingers up rather nicely!
Mike Stubblefield - www.capefearraceway.com
"If you're not racing to have fun, then you're doing it WRONG."
"All you need is WD-40 and Duct Tape. If it moves, and it shouldn't, use the Duct Tape. If it doesn't move, and it should, use the WD-40."
Stubbs is offline   Reply With Quote
Old 02-15-2010, 02:53 PM   #39
PowerHouse's Avatar
Heaters are back in stock!! The UPS man just dropped off some more.
Old 02-15-2010, 05:15 PM   #40
dirtlategrt02's Avatar
Cool
What kind of time frame does it take to get the whole engine heat soaked to fire it up?? I have one coming can't wait to put it to use!!
** GLENN "BULL" WORTHINGTON **
**TRI-COUNTY HOBBIES**
Support your local hobby shop!!!!!
dirtlategrt02 is offline   Reply With Quote
Old 02-15-2010, 05:39 PM   #41
boomgagem's Avatar
Trader Rating: 45 (100%+)
Send a message via AIM to boomgagem
Depends on the temperature outside. If it's below 40 or so, it can take a while, but if it's above that it takes about 10 minutes max.
I will say I have a heat gun and Mark's Engine Warmer, I haven't touched the heat gun since I bought the warmer. This is really worth the money, and works alot better than a heat gun.
boomgagem is offline   Reply With Quote
Old 02-15-2010, 05:48 PM   #42
Don't think I'll have to worry about temps that low down here in south florida. At least not very often, besides most would think its freezing at that temp and prolly stay home and not race Can the heater be left on for long periods of time or should it come off as soon as necessary when the temp of the engine is up?
Old 02-15-2010, 06:25 PM   #43
PowerHouse's Avatar
The pictures I posted were after 25-30 minutes. The engine's for the most part are ready to fire up in about 15 minutes and will be around 180-200 depending on ambiant temps as boomgagem mentioned.
Old 02-15-2010, 06:28 PM   #44
PowerHouse's Avatar
Once the temp is at it's highest, you can just let it simmer for as long as you want. I have left mine on and walked away and have come back 4 hours later and it is still sitting at the same temp it was when I left. The element only gets so hot so it can't continue to rise in temps unless you introduce more current which would probably fry it anyway.
Old 02-15-2010, 06:29 PM   #45
Thanks Mark, again you da man
I hope I get that warmer for the weekend to break in the new mill!!
