Old 02-13-2010, 01:08 PM   #1
Default Novarossi Carbs
Any one knows the difference between this carbs?
24040
24060
24063
your input is apreciated, thank you
Rui Almeida
Hamilton, Ontario
CANADA
I am not sponsored, these are the products I chose to support.
Serpent SRX8, Sanwa M11s, Sanwa SRX-BX servos, Picco 5TB
RAlmeida is offline   Reply With Quote
Old 02-13-2010, 10:31 PM   #2
mblgjr's Avatar
Trader Rating: 86 (100%+)
24040
24060
24063
24040 is an insertable, std. idle screw location. Blunt idle needle (classic Nova). Normally comes on the P5XL/XLT and all lower-line engines now. Idle speed screw is 'down' close to the flywheel when mounted on a buggy.
24060 is the exact same carb as 24040; but with the "reverse" idle screw location (puts the screw closer to the crankcase instead of down by the flywheel)...better for offroad/buggy applications since the idle speed screw isn't getting dirt flung onto it by the flywheel.
24063 is standard on the 367, +4series, ToroNero and new Nova/Losi Nitrotec. Is a 'reverse' location idle speed screw and newer "Long" style low speed needle that is tapered. Gets a little better fuel mileage. Discharge bore size is 9mm; but "straight" instead of conical and slightly larger 24040/60 carbs (so makes a little better torque). Slightly harder to tune for some people due to tapered LSN but IMO is a slightly better carb overall.
All carbs accept the same plastic Nova inserts.
All 3-bodies are meant for engine blocks that have the lower carb O-ring down in the block. Earlier Nova engines had the lower o-ring on the carb body in a groove (Long time ago).
You can interchange these 3-carbs within the Nova engine line without issue.
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 02-13-2010, 11:29 PM   #3
Thank you, really appreciated that info, and yes I find the 367 carb harder to tune than the others to the point of using a C6 L2G carb on the 367.
Rui Almeida
Hamilton, Ontario
CANADA
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
novarossi carb Johnnytc3 Onroad Nitro Engine Zone 7 06-04-2004 06:03 AM
