Old 02-13-2010, 12:44 PM   #1
kodiakbear7070's Avatar
Send a message via MSN to kodiakbear7070
Default Motor leaking?
I have a AE .15 pullstart motor trying to break in motor and have noticed some leaking around the pullstart back plate and also around the front of the flywheel and seems to be some on the exaughst side trying to figure out if this could be where the motor is running rich and some fluid coming from the exausht gasket that mounts to motor. Also running motor with air temp around the 30s on the outside I know this hard on them but just baught it and wanted to see what it could do.
kodiakbear7070 is offline   Reply With Quote
Old 02-13-2010, 05:25 PM   #2
smb17's Avatar
Send a message via AIM to smb17
Sounds like exhaust gasket to me but don't totally trust me. Way back in the day I've seen a few problems with the rtr AEs.
smb17 is offline   Reply With Quote
Old 02-14-2010, 07:29 AM   #3
Well Ive taken a closer look and that is what i am leaning towards now for the fact there is a lot of fuel residue around the bolts and flange that mounts to the motor
Old 02-14-2010, 08:44 AM   #4
hdcruzer's Avatar
Sounds like bearings. Seals are leaking. Since its coming from both ends, Id say both could be bad.....
Ofna Late Model-Losi 350-Losi RE 10-Hobbico CS170s
Coldfusion Fuel
Henchman Racing
hdcruzer is offline   Reply With Quote
Old 02-19-2010, 03:16 PM   #5
Ive broke down the motor and the bearings on both ends seems to be solid I went ahead and picked a set up if it continues to leak fuel then I will replace bearings.
Old 02-19-2010, 04:38 PM   #6
shanty140's Avatar
Always start with the easiest things first. Make sure all the seals are good, etc before you go taking apart bearing, etc. I used to always make the mistake of doing the hard things first, and it being a very simple fix.
Race Vehicles:
Mugen MBX6T - Ninja JX.21 with EB Mods Headbutton, O.S. 2060 Pipe, DX3R, Hitec 7955TG Servos on LiPo
HPI Cup Racer - Murfdogg Synergy 17.5, Tekin RS Pro, 2S 40C 4200mah, DX3R, Sav÷x SC-1251MG Servo
shanty140 is offline   Reply With Quote
MurfDogg Motor Works Discussion thread The MurfDogg Team and Company Discussions 1382 12-08-2014 05:38 PM
Sealing a motor piranha21 Nitro Off-Road 61 06-20-2009 06:58 PM
B4 Rear shocks leaking oil. Help needed yokfans Electric Off-Road 38 04-02-2009 10:44 AM
Engine leaking catkchun Malaysian R/C Racers 37 09-23-2007 05:38 PM
