rb engine protector
rb engine protector
hi guys,
neobuggy and rb have advertised the above.
i think it will solve my engine issues.
where can i get one????
Try This
You can acomplish the same by using silicone. Put a lighte oil around the shaft/inner race area-this will allow the shaft and race to turn after it cures. Then run a bead of silicone around the face of the bearing. Then spit on your finger and smooth it all done till you basically build another shield on the face. This wieghts nothing. And is very durable but will peel off when needed. I also pull my crank and take a tooth pick a put a very small bead on the shafts just ahead of where the bearing will set. This allows the silicone to smear backwards. And it improves the seal because its metal/metal there thats why it leaks when you park it.
