Old 02-11-2010, 06:42 PM   #1
Default Nova Plus 4 decisions
Hey guys
Well I have decided to get the Nova Plus 4... But I have a few decisions to make which I need you guys for assistance
One of the big questions is to whether to get the Plus 4 or the plus 4c, as I am after reliability (less chance of flame outs) and in general better quality... If you guys have any answers I am very keen to here them =)
Also a few more questions after I get my motor which of the following will I be better off with for better run time as my driving style eats quite a lot of fuel...
Which header:
Which pipe:
How much % nitro (also how many shims):
Thank you in advance
RUF-VK is offline   Reply With Quote
Old 02-11-2010, 06:56 PM   #2
littlelane's Avatar
i wiuld go with the ceramic bearings as far as the rest i use odo 97t and depending on the track i use the 9901 and 21 header for hard packed and the 9853 and 21 header for loose tracks i use torco 30% hope this helps if you have alot of questions on pipes try calling mark at powerhouse hes full of information and a great guy also a nova dealer
kyosho strr
Power House Mods
Cold Fusion RC Products/Team Driver
littlelane is offline   Reply With Quote
Old 02-11-2010, 06:58 PM   #3
Ye it is a bit hard calling anyone as I am not from the states...
What do you mean by ceramic bearing? Do you mean by the Plus4-c because it has a ceramic bearing?
Old 02-11-2010, 07:07 PM   #4
littlelane's Avatar
yea it has a ceramic rear bearing in my opinion they help the engine to spool up a little faster
kyosho strr
Power House Mods
Old 02-11-2010, 08:03 PM   #5
losi_racer's Avatar
Trader Rating: 25 (100%+)
Both are great engines. I do have both. you cant go wrong with either.
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 02-11-2010, 10:31 PM   #6
What are the disadvantages (if any) of the both in comparison to the advantages?
Old 02-11-2010, 11:02 PM   #7
Danny B's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to Danny B
If you are looking for a 21 Plus 4 look no further!
Sounds like you are overseas...email mark at Powerhouse...info@powerhousercperformance.com
I'm sure he would work out something with the shipping...
His work and knowledge is worth the money!
Tekno RC
Pro-Line Racing Tires, Futaba,
O.S., Hobbico, 92Zero Designs
Danny B R/C Products,
LRT Raceway, Evansdale, IA
Danny B is offline   Reply With Quote
Old 02-11-2010, 11:15 PM   #8
I am assuming there isn't much support of these engines in USA as I see the Go-Tech threads are going ballistic with support answers
Old 02-11-2010, 11:44 PM   #9
mblgjr's Avatar
Trader Rating: 86 (100%+)
Chill man. Nova has huge support and probably one of the better US Importer-supported service and distributors here in the US.
What you're asking the difference between is pretty minor.
The +4 vs. 4C isn't a huge difference at all. The 4C is slightly smoother in the bottom end, slightly less torque in the *very* bottom end; and revs a little higher. 4C gets the OEM ceramic rear bearing.
That's it. Nothing earth shattering. So far it seems the 4C gets just a little better runtime on average; but again...not staggeringly so. They're both right on top of each other. A lot of drivers can achieve 10+min runtimes from the 4 with the 41021/9901 setup (see below) on a buggy.
Are you aware that Nova just updated the 4-series again for 2010 to include a "team" engine? It's revised a little further. Visit www.novarossi.com and go to "novarossi" and "offroad" engines to view the details. It's like a +4C.1
http://www.novarossi.it/eng/products...EAM&brand=nova
Hope that helps a bit.
As far as nitro goes; run .80 shim for 30% nitro; .70 shim for 25%.
Novarossi C6TGC or OD97T plugs work well on 25-30% nitro.
Run a 6.5mm carb insert for mileage; 7mm for a little more power all around.
Pair it with a 41021/9853 manifold/pipe setup for Truggy. Use a 41021/9901 for buggy.
As far as Novarossi support...I think you should have looked just a *little* harder because the +4 and all your questions have been answered repeatedly in a couple threads...
The +4 has it's OWN thread:
http://www.rctech.net/forum/nitro-of...-plus-4-a.html
And a General Novarossi thread:
http://www.rctech.net/forum/nitro-of...ne-thread.html
Team Associated Reedy JConcepts.net FusionX USA
mblgjr is offline   Reply With Quote
Old 02-12-2010, 01:01 AM   #10
I searched up everywhere and I can't see a Nova plus4-c.1...
If there is a "revised" plus 4 coming out what would you guys do in my position...
1. Purchase a Nova plus-4 2009 (http://www.amainhobbies.com/product_...ine-Turbo-Plug)
2. Purchase a Nova Plus-4c 2009 (http://www.amainhobbies.com/product_...ine-Turbo-Plug)
If this new revised motor is coming out when will it be on A-main as I am overseas and order only from A-main...
Thankyou for help so far
Old 02-12-2010, 01:08 AM   #11
Unless this is the new "revised" 2010 model? http://www.novarossi.it/eng/products...-4T&brand=nova
Not too sure if it would be worth waiting as I am in no rush as I need the motor in 2-3months...
Old 02-12-2010, 07:51 AM   #12
bump
Old 02-12-2010, 12:03 PM   #13
mblgjr's Avatar
Yes, that is it. The name I used is just something I made up trying to help you understand that the new "Team" engine for 2010 is more of a revision; not a whole new engine. Notice I said it is "like"; not that it was in fact named that. The Team is further "fine tuned" just like the jump from a +4 to a +4C and now the +4Team.
I take it you didn't see the direct link I provided to Novarossi's website for the new engine?
If you can only buy from Amain just get a 4C and be done with it. It is a little better for most people all around. But again; there is not a *drastic* difference between a +4 and 4C.
It will probably be Mid-April before Amain has 'em in stock. You might see them a little before that; but until they put them on the site, you really won't know.
Old 02-12-2010, 06:24 PM   #14
I think I might just wait for this Nova plus 4 "team" as I already have a motor to run with in the meantime...
NOVAROSSI Engine thread.... r1harper Offroad Nitro Engine Forum 9685 Yesterday 01:28 PM
New Novarossi .21 offroad Plus 4 dsl Offroad Nitro Engine Forum 3759 09-01-2014 05:30 PM
Barracuda from Alex racing rcruv Electric On-Road 5110 02-27-2004 02:01 PM
