Old 02-11-2010, 05:15 PM   #1
Default RC8B gear grease?
Just building my RC8B now and noticed that the instructions do not specify any black grease on the diff housing/output shaft gears. does anyone out there put some grease on these? I'm talking about the large gear on the diff housing and the smaller gear that outputs to the centre diff.
Thanks.
bew79 is offline   Reply With Quote
Old 02-11-2010, 05:21 PM   #2
dcracing's Avatar
I use lithium grease.
BCE Mugen Mbx6
Novarossi
Byrons
dcracing is offline   Reply With Quote
Old 02-11-2010, 05:22 PM   #3
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Thanks.
I always used the Black grease on the Ring and Pinon. It help quite the drivetrain down a but, and i think it helps with wear slightly.
Bigedmond is offline   Reply With Quote
Old 02-11-2010, 05:24 PM   #4
Trader Rating: 47 (100%+)
I have been using this for a couple years now with great results. Helps the diff gears last.
http://www.amainhobbies.com/product_...Mobil-1-Grease
Team Associated - Reedy - JConcepts - KustomRCgraphics
Kingsbury is offline   Reply With Quote
Old 02-11-2010, 05:28 PM   #5
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Eureka Lube from TKO. I have used 1 tube for over a year, and take the diffs out after every other race weekend, little bit goes a long way, also prevents the gear's teeth from rusting if you blast the car with water hose.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 02-11-2010, 05:34 PM   #6
merdith6's Avatar
Default Wheel bearing grease
Just go to lowes and get any brand of wheel bearing grease. It is thick and really keeps those gears happy. No need for any special type. I use lubrimatic I think it's called, it's blue and comes in a nice sized paper jar with plastic lid...
Mad Dog drives a Mugen MBX-7, Novarossi engines, Clockwork Racing, Futaba radio, AKA/Proline Tires
merdith6 is offline   Reply With Quote
Old 02-11-2010, 05:40 PM   #7
jk1152's Avatar
You can buy a tub of Mobil 1 Red Grease for the same price at any auto store. Thats what I did. I used to by the 8.99 Hudy Graphite Grease.
jk1152 is offline   Reply With Quote
Old 02-11-2010, 06:54 PM   #8
thanks guys, i've used black grease because that was in the pack but will take into account your suggestions when it comes time for a rebuild.
Old 02-11-2010, 07:08 PM   #9
Go to Autozone or Tractor Supply Co. and get a tube of Green Grease.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 02-11-2010, 07:21 PM   #10
Kalgard Racing's Avatar
Mobil 1 is the shizz!!
Kalgard Racing is offline   Reply With Quote
Old 02-12-2010, 02:53 AM   #11
Mobil 1 and be done.
The Working Man is offline   Reply With Quote
Old 02-13-2010, 04:52 AM   #12
i am using ABRO NLGI 3 fully synthetic lithium grease...
Powered by: MASTERCARD and VISA
If you're in control, you're not driving it fast enough!
XRAY / NOVAROSSI / SANWA / AKA TIRES / BYRON FUEL
ganymede is offline   Reply With Quote
Old 02-13-2010, 08:04 AM   #13
tony montana's Avatar
Trader Rating: 65 (100%+)
+3 on mobil one
K.C. Guy. Team Xray - rc america
tony montana is offline   Reply With Quote
Old 02-13-2010, 09:35 AM   #14
Charles Godwin's Avatar
+1 for the Eureka Lube. Had a tube for 2 years now
DXR | CML Distribution | Paint by Turnip Paint | TKRgraphics.com
Charles Godwin is offline   Reply With Quote
Old 02-13-2010, 10:47 AM   #15
RC-ZOMBIE's Avatar
I use Lucas oil Red & Tacky very good prod.
Associated~Tekno~Mugen
RC-ZOMBIE is offline   Reply With Quote
