Old 02-11-2010, 04:45 PM   #1
Quad Racer 34's Avatar
Trader Rating: 4 (83%+)
Default Too much fuel line?
will it hurt or effect anything running to much fuel line for extra runtime? will it be too hard to get the fuel from the tank to the carb?
thanks
Dylan Gerard
Serpent - Desoto Racing - Picco - AKA - Hitec - RC Addictions Products - Tekin - VRP - Avid RC - SMC - MIP - SkipGear - The Ohio RC Factory
Quad Racer 34 is offline   Reply With Quote
Old 02-11-2010, 05:13 PM   #2
j_blaze14's Avatar
Trader Rating: 34 (100%+)
not good for racing cause too much fuel line may be illegal and if you are upside down too long it builds up a bigger air pocket so the motor will flame out, then when you come into the pits your pit guy will have your car on the box longer trying to prime it back up to run.
aGama A8 EVO - Werks B2 - Sidewinder
aGama A8E - TrackStar 150a, 2560kv, 3 and 4 cell
FlySky GT3B, Turnigy HV servos, SKY Lipos
AKA, Proline, Hotbodies Rubber
Elite Performance - HORRC.com
j_blaze14 is offline   Reply With Quote
Old 02-11-2010, 05:24 PM   #3
Frank L's Avatar
Trader Rating: 148 (100%+)
Too much fuel line also lowers the fuel pressure in the line and the engine has to work harder to suck the gas out of the tank. Think of it like a straw, a short straw you hardly have to put any effort into, a long straw with lost of bends and twists requires a lot more work to move the same amount of liquid to the end.
Old 02-11-2010, 06:05 PM   #4
Blackie001's Avatar
That's the same example I use.
What it means is you'll need to run richer carby setting to get the same amount of fuel as you do with a shorter line. So it's relative.
Air will move out of the line very quickly & you'd have to have a very large air bubble to cause a flame out. If you have a tank where the fuel pick up is locked at the bottom, so when upside down it sucks air, having a longer line will give you more time to get it turned over & as said, air moves very quickly, so when the air bubble hit the carby, it rushes through with very little resistance & there should be enough fuel in the motor to get past this, maybe with a few hesitations.
The negatives are - when your fuel capacity is measured at racing events they include the fuel lines. So you may be running with an illegal amount of fuel. Secondly, it may give the fuel more time to heat up, resulting in a less dense fuel.
Pete.
LRRCC - Treasurer, www.lrrcc.com
Losi 8ight T 2.0
MassiveMods MG66, Go 2072 Pipe
MassiveMods A Main Blue Dot C2
Spectrum DX3R, 2 x Ace 1015
Blackie001 is offline   Reply With Quote
Old 02-11-2010, 11:24 PM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
The longer the fuel lines the slower the reaction on the throttle..
When giving throttle exhaust pressure must build up and must speed up the flow with a lot of resistance in the lines.
With shorter lines the pressure is much quicker at the carb, with that you can lean out the LSN making the engine more powerful from the bottom and a better milage.
Speed is only fiction but a 130+km/h MRS4 is for real.
Roelof is offline   Reply With Quote
Old 02-12-2010, 08:17 AM   #6
All of the above
TLR - Spektrum - Horizon - TLR 8ight 4.0 - TLR 8ight-T 4.0 - TLR 22 4.0 - Orion
token is offline   Reply With Quote
Old 02-12-2010, 08:21 AM   #7
Madbrad's Avatar
Trader Rating: 29 (100%+)
So what is the correct length of fuel line you should be using ?
XT8 - Werks B5
Hyper 10SC Novak PRO ESC 4.5HV
Madbrad is offline   Reply With Quote
Old 02-12-2010, 08:33 AM   #8
fatdaddy's Avatar
im sure its on a car by car basis, but i like to keep mine in the 6-8" range
HPI Racing - Hot Bodies - D8 Army!
**Team Terribles** (Answer RC, Fastlane Graphix, Caster racing, M2C Racing, and Dialed Inc!)
fatdaddy is offline   Reply With Quote
Old 02-12-2010, 01:08 PM   #9
coviello's Avatar
also too short isnt good either. you cant run it directly from the back of the tank right to the carb. find a way to make it around the tank once then make your way to the fuel nipple. not really any more than 10-12''.
Barnstormers RC - Mugen Seiki - Hitec - EB Mods - Pro-line Racing - Lucky 7 RC
"Plug and play, Is not the way"
coviello is offline   Reply With Quote
Old 02-12-2010, 01:19 PM   #10
Old 02-12-2010, 04:37 PM   #11
pickle311's Avatar
Trader Rating: 31 (100%+)
I don't run mine around the carb like that. It puts the fuel too close to the head for my liking and only increases the fuel temp before it enters the carb, not by much but it does.
pickle311 is offline   Reply With Quote
Old 02-12-2010, 08:37 PM   #12
I'd be scared to have my fuel line that close to the brake linkage. It just screams "rip me!!"
Shaun Davis
VP ProUSA
Mugen Seiki/Alpha Engines
Team Trinity
Miniracer23 is offline   Reply With Quote
Old 02-12-2010, 10:56 PM   #13
i run my fuel line exactly like that picture on my rc8, and i have had 0 problems, my buddy runs his the same way with no problems, the break linkage doesnt bother it and fuel might get warm but it doesnt affect it due to the fact it still the rest of the lone to go threw to it has time to cool off before reaching the carb fuel inlet barb.
"when a man live's dangerous he's not afraid to die, ...... when a man's not afraid to die he live's stangely happy."
bigred0988 is offline   Reply With Quote
Old 02-12-2010, 11:00 PM   #14
fatdaddy's Avatar
i agree. heres mine. neat and clean
Old 02-13-2010, 06:25 AM   #15
ok thanks guys i just now remembered to check this thead. but yea i run my fuel line like the first picture of above. i drilled some holes in the top of the tank (not through the tank) and put zip ties there so the break linkage doesnt rip the fuel line because i actually had it almost happen. it was wearing grooves in the fuel line. so the zip ties hold it back good from that happening.
Dylan Gerard
Fuel Line Question datracing Nitro Off-Road 11 09-29-2009 09:02 PM
Fuel line length for 1/8 and 1/10 GP cars asw7576 Nitro On-Road 17 06-13-2008 10:52 PM
Fuel Line Filter?? 2Hard2Handle Nitro On-Road 20 07-30-2003 11:07 AM
