Old 02-05-2010, 05:06 PM   #1
madweazl's Avatar
Default Removing Loctite
I know heat works for removing screws but I'm trying to get loctite off of lexan belt guards (Optima Mid) and the fiberglass upper deck. Got any ideas (besides scraping)?
RadioPost
Mugen MBX7r | CRE Picco 5TR/2120 | Hitec 7950/7940
Tekno NB48 | B6 Pro/2058 | Hitec 7950/7940
Kyosho RB6 | Viper VTX10r/Reedy Mach 3 9.5 | Hitec 7940
Schumacher SX3 Pro | Viper VTX10r/Reedy Mach 2 8.5 | Hitec 7940
madweazl is offline   Reply With Quote
Old 02-05-2010, 05:10 PM   #2
smokinu's Avatar
Trader Rating: 60 (98%+)
some finger nail polish remover might work
Marcus P.
\\Speedzone USA//Savox USA\\Caster Racing Parts//
www.speedzoneusa.com. www.casterracingparts.com
smokinu is offline   Reply With Quote
Old 02-05-2010, 07:59 PM   #3
Integra's Avatar
Whack it with a driver....you can Shock the threads loose.....IF the part is strong enough to take it
Old 02-05-2010, 08:15 PM   #4
smokinu's Avatar
you must not have read it right, he said its on parts not screws.
Marcus P.
Old 02-06-2010, 08:30 AM   #5
madweazl's Avatar
I was able to get it off the fiberglass upper deck using a chisel tip on the soldering iron and 650 degree heat. As long as you keep moving the fiberglass will hold up to the heat, for a short period of time anyways.
Still investigating for the lexan parts. I emailed Loctite (got a reply in less than 24 hours), here is their response:
Aaron, if you are simply trying to remove the residue from these parts, it does require aggressive solvents like methylene chloride and this can attack both of those plastics unfortunately. There is a company called Dynaloy, Inc in Indianapolis who sells safe dissolving agents for many chemistries. Give them a call at 317 788-5694. They may offer a more suitable solution. The threadlockers are anaerobic chemistry.
RadioPost
Old 02-06-2010, 11:23 AM   #6
Integra's Avatar
my bad your right.
Old 02-06-2010, 01:32 PM   #7
madweazl's Avatar
my bad your right.
I search most things, just not Durango
RadioPost
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 07:58 AM
Help with removing engine mounts helgso Nitro Off-Road 25 07-01-2009 11:23 AM
removing damaged screws 32819toon Nitro On-Road 11 07-28-2007 04:51 AM
Any tricks to removing a siezed carb?.. fastharry™ Nitro On-Road 19 09-06-2003 10:13 AM
